Member's Forum What was your biggest project Disaster? We are asking e14 in our Join, Share & Win Competition
  • Locked Locked
  • Replies 45 replies
  • Subscribers 628 subscribers
  • Views 3624 views
  • funny
  • accidents
  • competition
  • halloween
  • makers
  • win
  • engineering competition
  • spooky
  • disaster
  • arduino uno R4
  • electronics
  • arudino uno
  • aske14
e14phil
e14phil over 1 year ago
Calling all makers, engineers, and tinkerers!
We are back for a second, and more SPOOKY month, asking you about your projects, spaces and adventures in engineering!
Last month we asked you about your workbench tips RE: What are your Tips for an Organized Workbench? [Ask e14 - Join, Share & Win Competition] September 2025
This month we want to know about the biggest project disaster you have experienced.
Photos: Historically "accurate" engineering accidents.
Competition
Join the element14 Community today and take part in our latest “Join, Share & Win” challenge.
It’s simple:
1. Register (or Login) for FREE
2. Answer this question by adding a reply / commenting:
3. Be in with a chance to WIN!
Share with us your best (hopefully lighthearted) watercooler story of how that one project sank, fell over or failed to start!
The Community Judge team will select our 3 favorite answers to win one of the prizes below.
Here’s what you could win:
Arduino Uno R4 Minima
October Competition [Now Closed]
The judging panel of E14Alice JoRatcliffe and myself have selected our winners in no particular order.
Please congratulate:
 battlecoder
javagoza
colporteur
Alice will be reaching out to you all to get your prizes via Direct message.
Congratulations, and this months competition begins today!
General Terms
What: Win 1 of 3 Arduino UNO R4 Minima
How: Sign up  or Sign in and Comment your answer to What was your biggest project Disaster?
When: Before October 31th 2025.
Anything else: Full terms are below, but we must be able to ship to the address in your account.
Entries close October 31st, 2025, so don’t wait!
Terms & Conditions
imagePDF
  • e14phil
    battlecoder
    javagoza
    colporteur
  • bradfordmiller
    bradfordmiller over 1 year ago in reply to colporteur
    https://web.mit.edu/~simsong/www/ugh.pdf
  • battlecoder
    battlecoder over 1 year ago
    I think my biggest disaster was when I put together a power supply kit. I didn't have a heat-sink for the power transistors yet, nor beefy cables for testing high currents, so I set the potentiometers to minimum voltage and minimum current. I had connected a volt and current meter in the supply for display, so I was shorting the outputs to test both voltage-limiting and current-limiting behavior. A couple of seconds after I applied power, the relatively thin cables I was using turned red hot and melted, and suddenly there was smoke everywhere. Turns out I wired the potentiometers incorrectly and at their "minimum" position they were actually set to both max current and voltage. The power transistor didn't survive that (I had to order a new one). Luckily that was the full extent to the physical damage. Damage to my morale on the other hand...
  • colporteur
    colporteur over 1 year ago in reply to Workshopshed
    I've been there. It lets the magic smoke out and things don't work no more.
  • Workshopshed
    Workshopshed over 1 year ago
    Most of my disasters have managed to be salvaged like the time I got the traces on a PCB backwards and solved the problem by soldering the ICs to the copper side.  Or when my 3D printer died mid project and I built the remaining parts from wood.
    But the most serious one was when I created a lighting dimmer on stripboard and touched the soldering iron to the live circuit which I thought was turned off. The copper strips melted like a fuse!
  • colporteur
    colporteur over 1 year ago in reply to javagoza
    Ouch!
  • dang74
    dang74 over 1 year ago in reply to DAB
    Well said.
    DAB over 1 year ago in reply to javagoza
    Remember the old saying "No good deed goes unpunished!"
  • beacon_dave
    beacon_dave over 1 year ago in reply to dougw
    That reminds me of some of the findings of those racing on the salt flats. They have found traces of salt inside fully welded up tubular frames and it corrodes them from the inside out. Looks solid from the outside but you can poke a screwdriver through it.
  • dang74
    dang74 over 1 year ago in reply to dougw
    Wow, its amazing how resilient electronics can be.
