Member's Forum RAW Bayer Capture Request for Ultra96-V2 Dual Camera Mezzanine with AR0144 (2022.2)
  • Subscribers 623 subscribers
  • Views 367 views
ApoorvaPatil
ApoorvaPatil over 1 year ago
Hello element14 community members,
I am using the Ultra96-V2 along with the Dual Camera Mezzanine, populated with the ON Semiconductor AR0144 sensor, and working with the 2022.2 toolchain.
The default dual-camera reference project works correctly, and we can capture greyscale frames.
However, for our project we need to capture RAW Bayer frames (RAW8/RAW10/RAW12) directly from the AR0144 sensor. This requires using the AP1302 in RAW passthrough mode, which is not enabled in the default example.
Could you please provide:
  • A RAW Bayer capture reference design (Vivado + PetaLinux) for AR0144
  • The appropriate AP1302 RAW sequencer firmware
  • Any guidance or documentation for enabling RAW sensor data streaming
Preferred configuration:
  • Sensor: AR0144
  • RAW Format: RAW8 or RAW10 or RAW12 Bayer
  • Tool version: 2022.2
  • Capture via v4l2-ctl or GStreamer
If earlier versions are available (e.g., 2020.1), instructions for porting to 2022.2 would be very helpful.
Thank you for your support.
Best regards,
Apoorva
