Member's Forum Portable Screwdriver Set
  • Replies 15 replies
  • Subscribers 624 subscribers
  • Views 1013 views
scottiebabe
scottiebabe 8 months ago
I was looking for a small, compact, and lightweight screwdriver/hex driver tool (or set) and found this:
A 1/4" hex ratcheting head with three removable 1/4" hex extensions.
You can place the extensions on one end to use it like a ratchet
Or configure it like a ratcheting screwdriver
The main tool body weights are shown below
Each of the hex shank bits have weights between 3g and 8g.
I like the general design of the tool. I am skeptical about the strength and reliability of the ratcheting head.
Time will tell, I will let you know it the tool fails.
  • colporteur
    colporteur 8 months ago
    In 1998 a wire-puller contractor standing at the top of a ladder said "a multi-blade screwdriver is the idea tool to carry." he reached into his pocket and pulled out on of these.
    Experience counts, SOLD, I own about five. They are scattered around job sites. The bits have double use now that cordless power drills are so prevalent. Unfortunately power tools is the reason I own five. I keep forgetting to return the bit to the screw driver and have to buy other screw drive to have a complete set of bits.
    I wish you the best of luck with the bit set. I carried one in my tool box for maybe ten years and never once use it. No that is not true. I did use it once when I miss placed my screw driver. Ratching screws in an out must be a skill I failed to acquire. In a pinch it is a tool I would use.
    You may find that odd removable exercise where a Cirque du Soleil type move with a socket bit sets might be the only way to remove the fastener. I hope those jobs are far and between.
  • gordonmx
    gordonmx 8 months ago
    What we call California screwdrivers
    • Vote Up +5 Vote Down
  • beacon_dave
    beacon_dave 8 months ago
    This is turning into a 'get your tool out' Friday.
    Here goes...
  • rsc
    rsc 8 months ago in reply to geralds
    These 2 have saved me work several times in tight spaces.imageimage
  • geralds
    geralds 8 months ago
    I work with this screwdriver sets:
    Wiha:
    Wiha Slimvario electric
    Torgue tools:
    https://wiha.com/gb/en/tools/torque-tools/wiha-torquevario-s-vde/
    with the bigger one:
    https://wiha.com/gb/en/tools/torque-tools/wiha-torquefix-tplus/torque-screwdriver-with-t-handle-torquefix-t/10146
    as well with the tool set "slimvario electric":
    https://wiha.com/gb/en/tools/highlights/innovations/tool-set-slimvario-electric/43465
    Wera:
    Wera
    https://toolrebels.de/en/products/wera-bike-tool-set-plus
    This is a very useful tool set, not just for bikes as well. This tool has also 8790 HMA-Zyklop 1/4" sockets, in standard dimensions.
    So, then I purchased also the complete set of the 8790 HMA-Zyklop 1/4" sockets, from 4mm up to 15mm, and the 8000 A Zyklop Speed-Ratchet with 1/4"-drive.
    With these excellent tools, I'm always on the go, whether on construction sites or in the workshop.
    The Wiha Slimvaro-electric sets are voltage-resistant up to 1000V. In electrical cabinets, the screws of the protective devices must be tightened to the manufacturer's specifications using a torque wrench, which is why I bought these.
    For larger jobs, I also have the large electrical screwdrivers from Wiha.
    Best Regards
    Gerald
  • wolfgangfriedrich
    wolfgangfriedrich 8 months ago in reply to scottiebabe
    Small red triangle down?
    A little riddle for Friday afternoon.
  • beacon_dave
    beacon_dave 8 months ago in reply to kmikemoo
    kmikemoo said:
    what you need to break a screw free
    You mean like that short-lived satisfying sound/motion only to realise that the head has indeed broken free but the threaded section still remains firmly seated where it was... Fearful
  • scottiebabe
    scottiebabe 8 months ago in reply to dougw
    The Canadian multi-bit screwdriver
    I also have some of the cheap ratcheting handles
    dougw 8 months ago
    An interesting twist on the convertible torque handle concept. It has that extra value cachet of being unique.
  • Aniket_kumar_raj
    Aniket_kumar_raj 8 months ago
    The hardest part while working with screwdriver kit is not losing any screwWilted rose
