I picked up something like this about three years ago. No regrets.
Though I can't help but feel like I'm also adding to the climate problem.
I was wondering about insulated ducting. Also the duct couplings I've seen so far have been pretty poorly designed and loosen with the duct expanding due to the heat.
Getting a good seal to the window depending upon what sort of window you have can also be problematic.
The wall-mounted mono blocks I think have two ducts, one for air in and one for air out with a heat exchanger and then a blower that circulates the air in the room so no pressure issue.
I was also wondering about more modular duct based systems. If I could mount a mono block unit on a wall in another room for good exchange to the outside with short ducts for the hot stuff, then run two ducts to the bedroom via the ceiling to circulate the air indoors, then that could work. It also keeps the motor noise outside of the bedroom as well.
Going to a split system would be the other way but then where to mount the outside unit.
I've used the portable ones before at work and they tend to radiate the heat back into the room from the duct before the hot air gets out the window, so not very efficient at actually cooling the room.
The meaco one came with a plastic, extending tube that you're meant to fit to the back of the air con unit. I don't use it, it radiates heat, and frankly the air flow is noisy.
I bought a tube like this:
Which, may be a bit overkill, but the heat is now mainly at the junction point between the tube and this, you get an adapter with the aircon unit, but with a thermal camera, it's only exhausted out the far end.
The unit itself gets generally a bit warm, but the unit does a good job at cooling. I suppose the only other wonderment is the whole "positive/negative pressure" from the air intake being indoors, but the temperature drop is so significantly noticeable it hasn't been a problem.
Not yet but I am thinking about a small unit for the bedroom.
Trouble is getting a short vent route to the outside with a mono block unit.
