Member's Forum Who's in the UK and has caved in and bought air conditioning?
  • Replies 93 replies
  • Subscribers 624 subscribers
  • Views 3230 views
  • air conditioning
  • heatwave
stanto
stanto 5 months ago
I picked up something like this about three years ago. No regrets.
Though I can't help but feel like I'm also adding to the climate problem.
  • ralphjy
    ralphjy 5 months ago in reply to beacon_dave
    Interesting data point is that for my solar system - summer is not when I get maximum dally energy production.  Even with extended daylight hours the performance degradation due to high operating temperature means that when I need AC most, available energy is reduced.
    I actually have to be careful using my mobile phone in bright sunlight when using the camera because it gets noticeably hot.
  • beacon_dave
    beacon_dave 5 months ago in reply to stanto
    A custom attachment for a window vent with an insulated vent pipe and a custom attachment for the standalone aircon unit could work. Parametric models for 3D printing so you can adjust the overall dimensions, duct diameters and fixing positions.
    I was also pondering if any readily available condenser radiators (automotive ?) could be used to DIY a system. Fit an appropriately-sized condenser radiator into the existing window vent opening with a fan mounted behind it, keeping the hot stuff outside, then an evaporator unit in the room with a fan cooling the room.
  • beacon_dave
    beacon_dave 5 months ago in reply to michaelkellett
    michaelkellett said:
    Mostly I work in an internal insulated room (100mm of insulating foam board and plaster board cladding inside). That gives quite good insulation in either direction although it was intended to keep me warm in winter.
    I think insulation generally works as long as you don't have external windows that quickly heat the air up inside and trap it there.
    I installed a split unit about 10 years ago but the outside part couldn't cope with the Scottish weather and died after about 5 years.
    One of the reasons I was looking at indoor mono block units. Less efficient but then not exposed to the UK weather.
    Yesterday when I left work at 6pm the air temperature was 26C, when I got home (which is on the sea coast) at 6:20 ,it was misty and the air temperature was 18C - which is why we don't need air con at home (yet). (In London it was 36C).
    Down the road from you in NW England and I was pulling cables indoors in 33C all afternoon. Leaving at 4pm and office thermometer indicated 29C. (My colleagues thought I had completely lost it when I commented that it felt cool in there. 4C lower makes a big difference.)
    Just as I was leaving, there was a thunderstorm and you could see the heavy rain instantly evaporating off the hot tarmac. It was like a dry ice fog effect on stage. Car thermometer said 30C.
    Got home and the bedroom upstairs was reading 33C. Windows open for 8 hours and it dropped by 5C to 28C. Outside forecast was for 19C, so in theory appropriate designed ventilation should be able to make it more comfortable for sleeping.
    I think though that there is a lot of heat trapped in the roof space that is very slow to release. Ridge tile vents might have helped there allowing for convection cooling.
  • beacon_dave
    beacon_dave 5 months ago in reply to shabaz
    I'd probably add 'architects' to that and bump it up the list with their 'form over function' mentality.
    There are planning regulations that can impact installations; easy for architects to work with at design time but can be problematic for an owner to retrofit.
    Also there doesn't appear to be much in the way of a standard form factor which allows you to replace an indoor unit with another without having to redecorate afterwards.
    In the US I see a lot of sash windows with the mono block air conditioner unit wedged into it. Almost as easy to buy and set up as a microwave oven. Most of the houses I have lived in here in the UK though have had casement windows, with vertically-hinged opening panes or horizontally-hinged vents, so that approach doesn't work.
    Likewise with portable units, there don't appear to be standardised ducts ready for you to plumb your vent pipe into, so you end up with a temporary duct running around the room and up a window to the nearest window vent.
    Cost to install and maintain and cost of electricity to run in this country. Although improvements in solar + battery could change that now. Unlike with heating in Winter, in Summer you tend to have a lot of sun when you need the energy for cooling.
    High density housing probably doesn't help either, can you imagine having your neighbours worn-out outdoor units rattling away either side of your open bedroom window all night long. Even the hum of a new unit will probably be enough to annoy some. Already happening with newly installed heat pumps.
    The trend may be changing now with the push for air source heat pumps which can also be run in reverse for cooling. Was likely installed to replace the gas boiler but during hot spells, I could see people starting to use it for cooling if it is there as a setting. Planning regulations appear to be more relaxed for heat pumps.
    It took a while for it to become the norm in vehicles over here. I don't use it much, just on the occasional very hot days.
    The biggest factor is probably the variable UK weather though. (It is not unusual to have four seasons in one day. People even like to write songs / tunes about it ! )  Most houses in the UK have primarily been designed to keep the rain out, and only more recently to keep the heat in to reduce heating energy costs in Winter. Until recently, extreme heat hasn't really been that much of an issue to justify the expense of installing / running air conditioning.
    michaelkellett 5 months ago
    I have a factory unit about 14 miles from my home in South West Scotland - about 300 miles North of London.
    I replaced it with a small mobile unit which just has to pump the heat out from the insulated room into the bigger space. It works OK for our temperatures.
    Air con is expensive to run in the UK because our electricity at retail prices is very expensive.
    shabaz 5 months ago in reply to robogary
    The buildings are different, it's not unusual to live in 100-year-old homes, so one is lucky if there's even good lighting and electrical connections in all the locations you want them; and existing ducting is almost unheard of. A lot of homes don't have the space for the outdoor units, and some really like their homes to be quiet. Some of it's also related to the energy mix, traditionally people used more gas in their homes perhaps (we still do), and a lot less electrical. And some of the reasons are cultural, air-con is seen as OTT, and some may not even ever switch it on in their vehicles.
    The combination of all that meant that air-con was one of those technologies that just ended up not being adopted by residential consumers in the UK, whereas it's super-normal in the US.
    shabaz 5 months ago
    Resisted it so far! But getting harder to ignore.
  • mp2100
    mp2100 5 months ago in reply to robogary
    . . . Because many homes don’t have AC there.  And it’s much hotter this week than normal.
    London was 87 F today and it’s at 51 N latitude.
  • robogary
    robogary 5 months ago
    Why is air conditioning such an issue in the UK ?
  • stanto
    stanto 5 months ago in reply to beacon_dave
    beacon_dave said:
    Going to a split system would be the other way but then where to mount the outside unit.
    That's where the compromises come in, especially if you're renting.
    beacon_dave said:
    Also the duct couplings I've seen so far have been pretty poorly designed and loosen with the duct expanding due to the heat.
    This is also true.
    Someone could make bank with a few little design tweaks that simply follow or make a sensible standard, even if it was for typical hvac.
