Member's Forum DIY Car Audio DSP Build — Tang Nano 9K + Orange Pi Zero 3.
  • Subscribers 630 subscribers
  • Views 31 views
JamesdaLion
JamesdaLion 4 hours ago
on my 2025 camry hybrid my audiocontrol lc2i took a crap on me and instead of buying another one i decided to just build my own dsp out of boards i already have laying on the bench
im running a skar audio setup (components and 12s) with a second optima yellowtop battery, a 4 farad capacitor and a victron 12/12-30a dc-dc charger to power my 1200 and 1000 watt rms amps. so power is solid. mainly just trying to fix the factory bass drop off from the stock stereo and be able to adjust my eq and crossovers from my phone with no lag
heres the parts im using for it
* sipeed tang nano 9k fpga: handles all the actual sound processing in real time so there is zero delay
* orange pi zero 3 (4gb): hooked up to the tang nano to host a local web page so i can pull it up on my phone and change the tuning on the fly
* pcm1808 stereo adc: grabs the signal coming off the factory speaker wires and turns it into digital audio for the tang nano
* pcm5102a stereo dacs (2 or 3 of them): turns the sound back into clean rca outputs for my amps. running thee for 6channels
* power and input protection: putting together a little board with resistors, caps, and diodes to drop the speaker voltage down so it doesnt fry the pcm1808, plus an isolated 12v to 5v converter and a pc817 optocoupler for the remote wire so i dont get ground loop or inverter noise
still waiting on the adc and dac boards to get here then im gonna breadboard it and test passing audio through
reason for the post is anyone have insight on problems I will have with this build and I'm aware it's probably fairly basic. you all have any wizard ways that can improve my build or take it to the next level. I don't want to go to my trunk to tune in my system anymore the back and forth sucks and it's still not getting it where I want it.
    michaelkellett 3 hours ago
    I can sort of guess what you are doing but some diagrams would make it clearer.
    The audio converters are very susceptible to psu noise.
    The Tang Nano 9k is a pretty light weight FPGA - do you have DSP code for it  (and have you used one before ?))
