Member's Forum How the times change.. .
  • Replies 17 replies
  • Subscribers 634 subscribers
  • Views 1686 views
element14Dave
element14Dave over 10 years ago
I wonder technology today will be the subject of such fodder tomorrow. Any guesses?
    mcb1 over 10 years ago in reply to Problemchild
    I did but never got a photo.
    It may have been the way they were displayed ...behind shiny glass surfaces never photo well....
  • bwelsby
    bwelsby over 10 years ago in reply to DAB
    I may have designed those Z80   based display systems. image
    But I also worked on bit slice based systems too.
    One system was 4k x 4k  resolution calligraphic display on a beam penetration colour moniitor .... seriously expensive tech.
    DAB over 10 years ago in reply to mcb1
    Close, they were run off two floppy disk drives and were used to feed text to Z80 controlled displays.
  • johnbeetem
    johnbeetem over 10 years ago in reply to mcb1
    I like the high-speed paper tape reader.  Middle of third cabinet.  Designed to be used with fan-fold paper tape.
    Here's a better image.
  • Problemchild
    Problemchild over 10 years ago in reply to dougw
    Ha ...Twin drives ..Total decadence!!! image
    Good spot there Doug'
    dougw over 10 years ago in reply to Problemchild
    The top white cabinet has two 8 inch floppy disk drives side by side.
    The floppy doors slide straight up to access the floppy slots.
    You can see a diskette in this image:
    Doug
  • Problemchild
    Not sure there's any 8" drives there only the tapes?!
  • Problemchild
    Problemchild over 10 years ago in reply to mcb1
    Spotted it Mark .... you were nearly crushed by it image
    Did you spot the Core memory assemblies on the side as you walked in ?
    dougw over 10 years ago in reply to mcb1
    Check the size of those 8 inch floppy drives and their cabinet....
    mcb1 over 10 years ago in reply to DAB
    Like this one.?
