Member's Forum need some help and advice on glove?
  • Replies 11 replies
  • Subscribers 635 subscribers
  • Views 1039 views
pge31
pge31 over 9 years ago
Hello everyone,
I am trying to learn to solder, but can't due to my disability. I would like to know if there is a special kind of glove that can prevent me from getting burn?
    jw0752 over 9 years ago
    Hi PaoGe Ge
    You might check out the type of gloves that people who work with knives use to prevent cuts. They would provide protection against bumping the solder iron for a short period of time. I am only guessing that this will help as you did not explain the problem you are having with the solder iron. Another technique that may work is to mount the soldering iron in a fixed position pointing towards you then move the work and the solder to the tip of the iron. Here is a picture of a chain mail glove.
    Here is a picture of the alternate soldering technique I mentioned:
    Give me more information on your specific problem and perhaps I can think of something else.
    • Vote Up +5 Vote Down
