Member's Forum Multiplexers for Audio application
  • Replies 8 replies
  • Subscribers 630 subscribers
  • Views 812 views
oksbwn
oksbwn over 9 years ago
Can someone recommend some multiplexers ideal for Audio application and tested ?
  • oksbwn
    oksbwn over 9 years ago in reply to michaelkellett
    Thank you Michael.
    michaelkellett over 9 years ago in reply to oksbwn
    You have to tell me about signal levels before I can suggest anything, Analog Devices make switches with maximum signal handling in the range 0-3v at the lowest up to +/-20V for high voltage chips. There is a big range of cost and other performance parameters as well.
    Cheapest dual 4:1 in Farnell
    Manufacturer:
    TEXAS INSTRUMENTS
    Order Code:
    1882277
    Manufacturer Part No
      CD4052BM96G3CD4052BM96G3
    Cheapest reasonable for Audio that might sound OK in Farnell:
    Manufacturer:
    INTERSIL
    Order Code:
    9663835
      DG409DYZDG409DYZ
       There are loads more - but you can't really choose one without defining better what you need from it.
  • oksbwn
    Hi Michael,
    Actually i have never worked on Audio before so please suggest me some IC and I will give them try.
    If you want good audio performance in HiFi terms then you must expect to pay for nice solid state switches.
    You need to decide if you need +/- 15V signal levels or can manage with 0-5V.
    Unless you do some tricks (basically shorting out the signals you don't want rather than passing the one you do want though the switch) then you will find that the multiplexer can easily be the dominant source of noise and distortion in your system.
    So before I could advise a particular chip you need to specify:
    normal (or reference) signal level
    required distortion at that level
    signal to noise ratio at reference level
    maximum signal level
    frequency response
    maximum permitted feed-through of unwanted channels at defined frequency and level
  • oksbwn
    oksbwn over 9 years ago in reply to Robert Peter Oakes
    Thanks for response Peter. My requirement is  I am trying to make a smart hoem audio system where I can select different input sources and output sources for audio. It's going to be POE (Using buck conveter if required) operated from the micro. The cahnnel can be any (2,4,8)depending upon the cost . The control interface can be direct digital or any protocol. Hope I am clear
    Bikash
  • Robert Peter Oakes
    Robert Peter Oakes over 9 years ago in reply to oksbwn
    You will need to provide alot more information then
    How many input channels to how many output channels
    What signal levels are involved
    is it to be battery operated or mains
    IE, what are your design criteria / selection criteria
    Regards
    Peter
  • oksbwn
    I have googled and then only I posted over here. I have already checked that page and some from Analog Devices. Thats why I mentioned tested. Moreover those IC are expensive over here and not easily available. If someone can recommend some IC those are cheap and readily available.
    Google my friend
    first page result shows this as a starter https://www.maximintegrated.com/en/products/analog/analog-switches-multiplexers/audio.html
