Member's Forum Share A Design Tip to be included in our next Engineers eBook
  • Replies 65 replies
  • Subscribers 636 subscribers
  • Views 4515 views
  • ebooks
  • share an idea
  • tech journal
  • essentials
  • learning center
  • design tips
jwatson
jwatson over 9 years ago
Let your fellow makers in on your design secrets here!
Have you found a solution to a common design problem?  Have you found an easier / cheaper way to do something?
Share your ideas with us for your chance to have your tip appear in Premier Farnell's edition of ebooks.
It’s your opportunity to share with your peers and promote your ideas or business at the same time.
Of course, please steer away from the obvious or too simple, such as ‘if you are writing software, take backups, OR drill holes this way instead of that way’.
We would like to create an ebook to provide both inspiration and assistance that help readers create interesting and fun projects, whether they are trying to kickstart a business or simply developing something for their own home.
Here’s some topics to get you thinking:
  • Using Maker boards – how do you get boards to do what you need, or configure boards to give you the inputs or outputs to do something cool?
  • Using Sensors – ideas for collecting information about what’s happening in the world, whether it’s temperature data or interfacing a camera...
  • Robotics and Controls – how do you control motors and movement? Ideas for making robots or simply just controlling a motor to close your curtains..
  • Displays – some boards have built-in displays, while don’t others? What are your best tips for displaying information in your projects?
  • IoT and Connectivity – soon almost everything will be connected, so tell us how you make it easier to get connected to the internet and transfer data...
  • Software development – what are your tips for writing better software, or just overcoming specific challenges? Show off your software expertise...
  • Just for fun – perhaps you’ve had a great idea for a new way of doing things, but aren’t sure if there are any serious uses. Tell us about your less serious tips and ideas!
We’re looking for tips of around 40 to 50 words with a simple diagram or image.
Share your ideas as a comment on this discussion and we will be in touch with you to let you know if your tip will be included in the next edition of ebooks.
    Jan Cumps over 9 years ago
    a simple one:
    Uninterruptible Power Supply for your USB powered Design by using an off-the-shelve Power Bank (like the one you use as smartphone backup) with pass-trough charging.
    Input is a USB wall wart, output goes to the gizmo.
    • Vote Up +6 Vote Down
    balearicdynamics over 9 years ago
    Tip #2
    Arduino educational shield for testing how digital potentiometers works.
    balearicdynamics over 9 years ago in reply to jwatson
    Hello Jane,
    I am posting some designs I think maybe useful but I am not sure if these can be considered "tips". Anyway if are useless for your ebook no matter.
    Enrico
    • Vote Up +5 Vote Down
    Tip #1
    Arduino alphanumeric 8 bits LCD device with three cables only using a shift register. Available circuit schematics, pcb and prototypes, video etc.
  • jwatson
    Don't forget - we can all refer to Forums  for free peer advice on everything EAGLE!
    This is a great resource, as are EAGLE CAD Libraries - free to all element14 registered members.
