Member's Forum Share A Design Tip to be included in our next Engineers eBook
  • Replies 65 replies
  • Subscribers 636 subscribers
  • Views 4450 views
  • ebooks
  • share an idea
  • tech journal
  • essentials
  • learning center
  • design tips
jwatson
jwatson over 9 years ago
Let your fellow makers in on your design secrets here!
Have you found a solution to a common design problem?  Have you found an easier / cheaper way to do something?
Share your ideas with us for your chance to have your tip appear in Premier Farnell's edition of ebooks.
It’s your opportunity to share with your peers and promote your ideas or business at the same time.
Of course, please steer away from the obvious or too simple, such as ‘if you are writing software, take backups, OR drill holes this way instead of that way’.
We would like to create an ebook to provide both inspiration and assistance that help readers create interesting and fun projects, whether they are trying to kickstart a business or simply developing something for their own home.
Here’s some topics to get you thinking:
  • Using Maker boards – how do you get boards to do what you need, or configure boards to give you the inputs or outputs to do something cool?
  • Using Sensors – ideas for collecting information about what’s happening in the world, whether it’s temperature data or interfacing a camera...
  • Robotics and Controls – how do you control motors and movement? Ideas for making robots or simply just controlling a motor to close your curtains..
  • Displays – some boards have built-in displays, while don’t others? What are your best tips for displaying information in your projects?
  • IoT and Connectivity – soon almost everything will be connected, so tell us how you make it easier to get connected to the internet and transfer data...
  • Software development – what are your tips for writing better software, or just overcoming specific challenges? Show off your software expertise...
  • Just for fun – perhaps you’ve had a great idea for a new way of doing things, but aren’t sure if there are any serious uses. Tell us about your less serious tips and ideas!
We’re looking for tips of around 40 to 50 words with a simple diagram or image.
Share your ideas as a comment on this discussion and we will be in touch with you to let you know if your tip will be included in the next edition of ebooks.
  • tpcipri
    tpcipri over 6 years ago in reply to shabaz
    Great tip! I've used spreadsheets to do basic circuit analysis or when I was trying to find just the right resistor set where I was having to constanly recalculate all the resistors to change one. It is much simpler than doing simultaneous solutions or even simulations! Later I would run simulations to veryfy the design was good before committing it to hardware.
  • tpcipri
    tpcipri over 6 years ago in reply to mcb1
    There are pros and cons to using this method that others have brought up. Should you go this route my recomendation is to do a Save As before making changes to a file so you don't accidentally make changes and overwrite the previous version. When versiong by date, as I called it, I would use a yymmdd format and put it in front of the name so that the file names sort and stay together nicely.
    Example. File name is MyFileName.docx:
    SaveAs name: 200408MyFileName.docx
  • tpcipri
    tpcipri over 6 years ago in reply to rsc
    Using a zener is a quick and dirty way to get a regulated voltage using parts you may have around. I wouldn't recommend it for production boards for two reasons:
    1. The zener voltage will vary from board to board and could lead to stability problems.
    2. Noise rejection will be sacrificed. It could be improved by putting low ESR caps across the zener. The input and output caps should still go to ground and not to the zener-ground connection.
  • weiwei2
    weiwei2 over 7 years ago in reply to koudelad
    there power bank that has always on feature, we have to select one that has such feature if we want to use it
  • phoenixcomm
    phoenixcomm over 7 years ago in reply to shabaz
    Never in a Billion Years. Just use a DB I put the code for mine down below.
  • phoenixcomm
    Dear god! YASS (yet another spreadsheet)! you haven't learned your lessons yet. I use MySQL I have 3 tables: this might be overkill for some but I have a lot of military parts, so that why I have the NSN and others. why three tables you ask ok here goes
    1. holds manufacturer information.
    2. holds information about the part itself. The Key field is Info_ID.  such as pn, manufacture(id) and others that you might never use.
    3. holds the history of the part such as the quantity, cost, condition (new, used, etc) and two location fields one is LOC for external storage and LAB which is my current parts.
    I don't even have a front end for this it was all built inside phpMyAdmin.
    LETS STAMP OUT THE PLAGE OF SPREADSHEETS!!!
    1)
    CREATE TABLE IF NOT EXISTS `Manufacture` (
      `Man_ID` int(11) NOT NULL auto_increment,
      `name` varchar(100) NOT NULL,
      `CAGE` varchar(6) default NULL,
      `RN Number` varchar(10) default NULL,
      `Parent` varchar(6) default NULL,
      `ACTIVE` enum('YES','NO') default NULL,
      `Replaced` varchar(6) default NULL,
      `Logo` varchar(50) default NULL,
      `www` varchar(256) default NULL,
      `phone` varchar(20) default NULL,
      PRIMARY KEY  (`Man_ID`)
    ) ENGINE=MyISAM  DEFAULT CHARSET=latin1 AUTO_INCREMENT=390 ;
    2)
    CREATE TABLE IF NOT EXISTS `info` (
      `Info_ID` int(11) NOT NULL auto_increment,
      `Aircraft_ID` int(11) default '0',
      `Man_ID` int(11) NOT NULL,
      `Part` varchar(50) default NULL,
      `Alt_Part` varchar(50) default NULL,
      `UPC` varchar(20) default NULL,
      `Replaced` varchar(50) default NULL,
      `Description` varchar(200) NOT NULL,
      `PMA` enum('NO','YES') default NULL,
      `Spec` varchar(55) default NULL,
      `NSN` varchar(16) default NULL,
      `MRC Features` enum('NO','YES') default NULL,
      `MRC_ID` bigint(20) default NULL,
      `INC_ID` int(11) default NULL,
      `WPN_SYS_list` varchar(500) default NULL,
      `Model` varchar(25) default NULL,
      `ROHS` char(1) NOT NULL,
      `FSG` int(11) default NULL,
      `EEM_ID` bigint(20) default NULL,
      `Sort1` char(10) NOT NULL default 'U',
      `Sort2` varchar(10) default NULL,
      `Sort3` varchar(10) default NULL,
      `Sort4` varchar(10) default NULL,
      `Notes` varchar(5000) NOT NULL,
      `PRIVATE_NOTE` varchar(500) default NULL,
      `Pricing` decimal(8,3) default NULL,
      `Punits` int(11) default NULL,
      `Pwait` int(4) default NULL,
      `pdfs` varchar(50) default NULL,
      `Photo` varchar(100) default NULL,
      `Photo2` varchar(50) default NULL,
      `info_date` timestamp NULL default CURRENT_TIMESTAMP,
      `webcat` timestamp NOT NULL default '0000-00-00 00:00:00',
      PRIMARY KEY  (`Info_ID`)
    ) ENGINE=MyISAM  DEFAULT CHARSET=latin1 AUTO_INCREMENT=747 ;
    3)
    CREATE TABLE IF NOT EXISTS `history` (
      `Info_ID` int(11) NOT NULL default '0',
      `Quan` int(11) NOT NULL,
      `CC` enum('NW','NS','RP','BER','AR','SCRP','NIB','USD','OBX','SV','REFB','RFS') NOT NULL,
      `Serial` varchar(50) default NULL,
      `Cost` decimal(10,3) NOT NULL default '0.000',
      `db_date_stamp` timestamp NOT NULL default CURRENT_TIMESTAMP,
      `Notes` varchar(200) default NULL,
      `Location` varchar(500) default NULL,
      `Lab` varchar(100) default NULL
    ) ENGINE=MyISAM DEFAULT CHARSET=latin1;
  • e14phil
    e14phil over 9 years ago in reply to Instructorman
    Thanks Mark,
    That is something some one showed me at my local hackspace.
    BONUS FACT:  if you are new at soldering or teaching a newbie, the washer acts as a head sink to protect the components that could be damaged from excessive heat.
  • ntewinkel
    ntewinkel over 9 years ago in reply to shabaz
    I know, right? That washer was unexpected - such a simple yet useful idea!
    shabaz over 9 years ago in reply to e14phil
    It had some cool tips! I like the one to hold wires together in a plane by using a washer - stunningly simple but I'd never have thought of it.
    I hadn't realized there was quite a collection in that ebooks location - they were interesting to read.
    • Vote Up +5 Vote Down
  • Instructorman
    Instructorman over 9 years ago in reply to e14phil
    Thanks e14phil!
    I had forgotten about submitting a tip.
    I'm humbled to be included among the highly qualified E14 top members that provided their time tested advice.
    All of the tips are spot on and very helpful.
    My surprise favorite is actually your "Ring of fire" tip for adding some mechanical rigidity to wires that need to be soldered together.  I had not thought of that, nor had I seen anything like it in all my years in this business.
    I have struggled with that very task many times, using multiple fingers and thumbs to hold the soldering iron, while guiding in the solder spool, while stabilizing the twisted wires, while trying to focus everything under a magnifying lamp. Argh!
    Your tip will save time, improve safety, and preserve sanity.  Well done!
    Mark A.
