Member's Forum Share A Design Tip to be included in our next Engineers eBook
  • Replies 65 replies
  • Subscribers 600 subscribers
  • Views 3743 views
  • ebooks
  • share an idea
  • tech journal
  • essentials
  • learning center
  • design tips
jwatson
jwatson over 9 years ago
Let your fellow makers in on your design secrets here!
Have you found a solution to a common design problem?  Have you found an easier / cheaper way to do something?
Share your ideas with us for your chance to have your tip appear in Premier Farnell's edition of ebooks.
It’s your opportunity to share with your peers and promote your ideas or business at the same time.
Of course, please steer away from the obvious or too simple, such as ‘if you are writing software, take backups, OR drill holes this way instead of that way’.
We would like to create an ebook to provide both inspiration and assistance that help readers create interesting and fun projects, whether they are trying to kickstart a business or simply developing something for their own home.
Here’s some topics to get you thinking:
  • Using Maker boards – how do you get boards to do what you need, or configure boards to give you the inputs or outputs to do something cool?
  • Using Sensors – ideas for collecting information about what’s happening in the world, whether it’s temperature data or interfacing a camera...
  • Robotics and Controls – how do you control motors and movement? Ideas for making robots or simply just controlling a motor to close your curtains..
  • Displays – some boards have built-in displays, while don’t others? What are your best tips for displaying information in your projects?
  • IoT and Connectivity – soon almost everything will be connected, so tell us how you make it easier to get connected to the internet and transfer data...
  • Software development – what are your tips for writing better software, or just overcoming specific challenges? Show off your software expertise...
  • Just for fun – perhaps you’ve had a great idea for a new way of doing things, but aren’t sure if there are any serious uses. Tell us about your less serious tips and ideas!
We’re looking for tips of around 40 to 50 words with a simple diagram or image.
Share your ideas as a comment on this discussion and we will be in touch with you to let you know if your tip will be included in the next edition of ebooks.
  • e14phil
    e14phil over 8 years ago +8
    Thank you to everyone who submitted a tip! We were able to use tips from: ipv1 shabaz ntewinkel Instructorman rachaelp michaelwylie fvan Jan Cumps https://www.element14.com/makertips
    balearicdynamics over 9 years ago in reply to jwatson +6
    Tip #1 Arduino alphanumeric 8 bits LCD device with three cables only using a shift register. Available circuit schematics, pcb and prototypes, video etc.
    Jan Cumps over 9 years ago +6
    a simple one: Uninterruptible Power Supply for your USB powered Design by using an off-the-shelve Power Bank (like the one you use as smartphone backup) with pass-trough charging. Input is a USB wall wart…
  • COMPACT
    COMPACT over 8 years ago in reply to Jan Cumps
    I do this all of the time!
  • COMPACT
    COMPACT over 8 years ago in reply to COMPACT
    It's just emulating how a notebook computer's power works.
  • COMPACT
    Tip Top
    Don't trust portable hard disks for backups!
    One drop and it's broken.
    Backup on different types of media to mitigate the risk!
  • ntewinkel
    ntewinkel over 8 years ago in reply to COMPACT
    Good point about location - Dropbox and Google Drive are good for offsite backup.
  • ntewinkel
    punch cards, 5-1/4" floppies, 3.5" floppies, USB sticks, SD cards, Memory sticks.
    More seriously though, gotta love those USB sticks!
    I always tell my clients to keep a few backup copies of the source code on a USB stick - cheap and tiny enough to leave in a safe or two in different places.
    Plus those little suckers seem to do well even if they go through the wash.
    I suppose an external drive with SSD would be pretty solid too.
  • ipv1
    ipv1 over 8 years ago
    Tip for beginners
    For basic Oscilloscope and Function Generator needs, use your Android Phone or iPhone. There are lots of apps that allow you to use your headphone jack as a source of signal input as well as output and can be very handy at times. Make your own cable from an old headphone or solder up a new one and add alligator clips at the end. Works for beginners with a budget.
  • COMPACT
    COMPACT over 8 years ago in reply to ipv1
    I wouldn't because the bandwidth and signal amplitudes are limited for audio use.
    The general rule of thumb for oscilloscope selection is 5x the maximum analog signal frequency component being observed.
    I forked out a whole years savings for my oscilloscope in the early 1980's and it was only a dual trace 20MHz.
    It was able to display 10 MHz digital clock signals but with considerable distortion due to its limited bandwidth.
    (with square waves being morphed into sine waves)
  • assissin
    assissin over 8 years ago
    Drilling PCB holes.
    To reduce the drill bit "wandering" when drilling holes in your PCB...
    Before processing etch stages, copy a layout of the final version to your desktop. Open this copy and reduce all component and mounting holes to 0.5mm, save and close. Process in your usual way (photoresist-etch, hot or cold toner transfer or milling using this copied version.
    If you are milling your PCB, on completion of using this method you now load your original excellion drill file before removing the PCB from the CNC mill. With the "real" excellion files to drill the holes to the required sizes
  • COMPACT
    COMPACT over 8 years ago in reply to assissin
    That's wanderful!
    Also useful if you use sharp drill bits rotating at the right speed and the right feed rate.
    mcb1 over 8 years ago in reply to assissin
    Used that trick and it works great.
    I almost forgot about that now that boards fom our asian friends are cheap and have everything done for you.
