Member's Forum Rapsberry Pi Build
  • Replies 7 replies
  • Subscribers 635 subscribers
  • Views 783 views
  • help
  • raspberry pi
  • gmail
Rapsberry Pi Build
don7875
don7875 over 8 years ago
Hi guys I need some help I am following a Guide to feed my cat via email using a raspberry pi here is the link. http://storiknow.com/automatic-cat-feeder-using-raspberry-pi/  seems pretty straight forward but when I get two part two I put in my username and password and get this error below back and im an 100% sure I do not have the wrong username and password. any suggestions?
The Error I am Getting:
Logging in as <siguykittykat>
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "GmailWrapper.py", line 15, in __init__
    self.login()
  File "GmailWrapper.py", line 20, in login
    server.login(self.userName, self.password)
  File "/usr/local/lib/python2.7/dist-packages/imapclient/imapclient.py", line 284, in login
    raise exceptions.LoginError(str(e))
imapclient.exceptions.LoginError: [AUTHENTICATIONFAILED] Invalid credentials (Failure)
My code for the GmailWrapper.py
#!/usr/bin/env python
from imapclient import IMAPClient, SEEN
SEEN_FLAG = 'SEEN'
UNSEEN_FLAG = 'UNSEEN'
class GmailWrapper:
    def __init__(self, host, userName, password):
        #   force the user to pass along username and password to log in as
        self.host = host
        self.userName = userName
        self.password = password
        self.login()
    def login(self):
        print('Logging in as ' + self.userName)
        server = IMAPClient(self.host, use_uid=True, ssl=True)
        self.server = server
    #   An Id in this case identifies a specific email
    def getIdsBySubject(self, subject, unreadOnly=True, folder='INBOX'):
        #   search within the specified folder, e.g. Inbox
        self.setFolder(folder)
        #   build the search criteria (e.g. unread emails with the given subject)
        self.searchCriteria = [UNSEEN_FLAG, 'SUBJECT', subject]
         if(unreadOnly == False):
            #   force the search to include "read" emails too
            self.searchCriteria.append(SEEN_FLAG)
        #   conduct the search and return the resulting Ids
        return self.server.search(self.searchCriteria)
    def markAsRead(self, mailIds, folder='INBOX'):
        self.server.set_flags(mailIds, [SEEN])
    def setFolder(self, folder):
        self.server.select_folder(folder)
  • don7875
    don7875 over 8 years ago in reply to storiknow
    Thanks for your help Sam I have it working and will be ordering the motor this weekend!!
  • john-broderick@hotmail.com
    john-broderick@hotmail.com over 8 years ago in reply to storiknow
    Who is Joe ?
  • storiknow
    storiknow over 8 years ago
    Hey Joe:
    I'm actually the author of that post and am glad to see you're giving it a go! If you're following the tutorial directly, you'll have setup "two-step authentication" in your Gmail account, and then you'll have generated a password. if you did this, the password will be a 16 character code and will separate every 4 characters with spaces. Here's an example: xxxx xxxx xxxx xxxx.
    When you create the password initially it'll pop-up for you, at which point you likely copy/ pasted it. I've found that, once pasted, the spaces will be removed and you'll be left with something like "xxxxxxxxxxxxxxxx". This is no longer a valid password!
    Give it another shot, but this time manually type the password in and be sure to include the spaces:
    gmailWrapper = new GmailWrapper('imap.gmail.com', 'userName', 'xxxx xxxx xxxx xxxx');
    Also, enclose each parameter in single quotes. If you continue having issues, feel free to contact me through the site, I'll be happy to debug with you.
    Good luck!
  • erlemannoü
    erlemannoü over 8 years ago
    try changing lines:
    to:
            self.userName = str(userName)
            self.password = str(password)
  • the48sicks
    the48sicks over 8 years ago in reply to don7875
    Sorry that didnt sort it Jon!
    I would just double check that the toggle for less secure apps has saved in the On position (sometimes it doesn't)  and possibly even use a Microsoft outlook client just to double check that your remote access is indeed working. At least then you can rule that out and re-focus on the library
    I have to go through this process to archive off our staff mail boxes and sometimes the external auth can be a bit funny.
  • don7875
    don7875 over 8 years ago in reply to the48sicks
    Thanks Matt,
    Man I was  so excited I thought that would be it but I am still getting the error.
    Thanks for taking the time to help me out though,
    Joe
  • the48sicks
    Just having a stab in the dark here, ive not used the wrapper myself. however!
    ** assuming you are using a google account and the login details are correct **
    When using these kinds of things there is a setting in google to allow  IMAP and "Insecure systems"
    In google go to My Account > Sign in and Security then down the bottom change "Allow less secure apps" to   "ON"
    You may also need to go into your gmail settings and allow IMAP   Settings > Forwarding and POP/IMAP  "Allow IMAP"
    HTH
    Matt
