Balearic Dynamics Soon: TiltPan Arduino Shield for GoPro Cameras
  • Date Created: 9 Apr 2015 11:21 AM Date Created
  • Views 1330 views
balearicdynamics
balearicdynamics
9 Apr 2015
Coming soon, at least with a shooting, the TiltPan Arduino Shield evolution: the GoPro support with PC Control. Enjoy the images image
    beacon_dave over 10 years ago in reply to dougw +1
    Kessler Crane CineDrive is a nice mechanism if you ever get the chance to use one. However even it won't be smooth when operated at higher speeds. CineDrive Showcase — Kessler Also note that some of the…
    Also note that some of the poor video quality is actually due to panning too fast and will happen even on high end professional equipment. Rule of thumb when shooting at 24fps is around 7seconds minimum to pan across the viewfinder frame. For a standard lens this can typically mean around 20-30s just to pan through 90degrees whereas most people will attempt to do it in 5 or less. For telephoto lenses you can be looking at _much_ longer durations. If you are tracking a person or object in frame then you can often get away with faster as the viewer's eye is distracted, but for scenic shots then the strobing etc. artefacts will become very noticeable.
    dougw over 10 years ago in reply to balearicdynamics
    looks good.
    If you come up with a really smooth motor and rotation you will have great demand for the device. Most pan-tilt mechanisms vibrate and shake far more than the size of the pixels in the sensor, and it causes blurring and loss of detail in the video. It also generates audio noise, which is annoying.
    balearicdynamics over 10 years ago in reply to screamingtiger
    Hello Joey,
    not it is not a gimbal but a real pan/tilt mechanism. As a matter of fact I have already evolved the prototype and really soon (now it is late respect the date of this project, but not always it is possible to follow the desired timeline) I will publish other articles on this project. I will notify here the link of the next updated articles.
    Enrico
  • screamingtiger
    screamingtiger over 10 years ago
    Is this a gimbal (auto level) just a way to remotely control a camera?
    Interested, I am working on a single axis gimbal now using an arduino.
    I know I know a psoc is better but I have a few pro minis left to use up!
