Legacy Personal Blogs 1 Meter of Pi Raspberry Farm
  • Author Author: stevotech
  • Date Created: 12 Oct 2020 3:14 PM Date Created
  • Views 839 views
  • 1meterofpi
stevotech
stevotech
12 Oct 2020
Four days since announcement of Sponsored Challengers finalists/winners and I have mapped out the 10-12 weeks programme of work:
  1. Draft mechanical designs and detail materials and equipment for the complete module.
This will be the most difficult and I am considering making a scale-model to see how the various sections will best fit together. I will probably use standard plastic shapes as these could probably be produced by 3D printing for the final build (and a 3D printer might be part of the ‘onboard’ support equipment).
  1. Utilities and services to be designed into the assembly and miniature components selected.
Once the first assembly has been roughed out, I can see how water supplies valves and pipework can be fitted, together with any cabling runs for electrical power and sensors/controls.
  1. Materials, equipment, and components sourced and procured
  2. Mechanical structure and relevant sub-sections constructed
  3. Equipment and components, including control systems, fitted
At this stage I will have a unit with sections, including a ‘dummy’ central tower that I can manually move around and position. Depending on those experiments, I might make and fit some simulated drive units and controls that I can run either in single steps and/or complete cycles.
  1. Breadboard designs of control system utilising Raspberry Pi 4 2GB, a Pimoroni PIM487 Automation HAT, PIM486 Enviro HAT, and a PICO HAT Hacker PCB (and other items) supplied in the Challenge Kit by Element14
  2. Assembly and hook-up to scale model for first phase testing and ‘dry’ runs
  3. Final check of structure and operation, including additions, before procuring materials and equipment for full sized module
  4. Make of full-sized sections and construction of first main module
  5. Trial runs ‘dry’ and then full ‘wet’ testing
1meterofpi@
    DAB over 6 years ago +1
    Good plan, I hope it all works out for you. DAB
