Legacy Personal Blogs Accurate low-current measurements with a scope
  • Author Author: mlease
  • Date Created: 25 May 2015 3:12 PM Date Created
  • Views 1652 views
  • low_power
  • low_current
  • measurement_accuracy
  • ucp100
  • low_current_measurement
  • measurement_error
  • current_probe
mlease
mlease
25 May 2015
Last week was incredibly busy so I wasn’t able to put the time in to complete the third part of the “Leakage currents & current leaks” post. This will be a short post with a link to a white paper on our website for more details.
Most engineers consider the oscilloscope their first tool of choice for hardware development work. Yet very few engineers ever consider how accurate their scope is. Most of the major oscilloscope manufacturers place great importance on the timing aspects of their products. Multi-gigahertz sample rates are fairly common today in mid-range digital scopes today yet most of those scopes only have 8-bit A/D converters. While timing accuracy is often spec’d in double-digit ppm, voltage measurement error on the same scope can be as much as the signal level you need to measure using a scope’s lowest volts/division setting.
Read the complete post at http://cmicrotek.com/wordpress_159256135/.
  • mlease
    mlease over 11 years ago
    Good points. Part of understanding your test equipment is knowing the conditions the specs apply for. It is fairly common even for modern-day scopes to specify a 30 minute warm-up in order to meet performance specs. That isn't so much of a problem as it is something an engineer must be aware of in order to get the most accurate measurements possible. Up-to-date calibration is also critical to getting measurements you can believe.
  • mlease
