Legacy Personal Blogs AEC and Elesta Relays
  • Date Created: 11 Apr 2011 1:38 PM Date Created
  • Views 434 views
  • elesta
  • guided
  • relays
  • force
  • safety
e14 Contributor
e14 Contributor
11 Apr 2011
The Elesta force guided relays utilize mechanically linked contacts to ensure that break and make contacts are never closed at the same time, providing an elegant switching solution.  If normally open load contacts should stick closed, the normally closed contacts (used as a monitor point) will remain open for your control system to recognize the stuck closed failure, and most importantly, shut down dangerous equipment. Throughout the entire life of the relay, you can count on Elesta.
From laser cutters, x-ray equipment, safety control panels, or a shut off switch; any machine that interacts with people needs safety controls, they need Elesta.
Supplying top of the line components is only a small part of what we do. The heart of our business is developing solutions for your unique application needs. American Electronic Components, Inc. specializes in solving your needs. We will work with your engineers to develop a custom solution to your problem.
Please dont not hesitate to contact us if you have any questions or would like more information.
