makes sense in the video? Isn't Serial always different from 0, because it's a static object that has a non-zero address? even if Serial.begin(9600) fails?
Jan Cumps Apparently, a reference to Serial in an if or while argument context evaluates to true if the specified serial port is available else there is a permanent/temporary error. There must be something hidden in the compilation/interpreter that treats Serial special. An if( Serial.isConnected() ) would be better. Secrets are bad engineering practices but what can you do? I cannot find any documentation of the static Serial object other than what's in the arduino.cc API. Have you?
To guard against a single spurious failure instance, I use this in setup() instead of the if-statement for Serial applications:
int count_down = 3; while( ! Serial ) { // Sleep 1 second if not yet ready. delay( 1000 ); // Tried the maximum allowed times already? if( count_down-- < 1 ) { // Tried 3 seconds to get the serial connection ready - giving up. // Timeout error processing goes here } }
Ok, Jan Cumps earned the "King for the Day" title. I've been busy cleaning up my own mess (one of those "no good deed goes unpunished" stories).
King of which country? How about the USA? Stay longer. The American Congress is useless so we might as well have a King. And, you'd probably do a lot better than the 2 individuals currently running President in any case!
"The Arduino Leonardo board uses Serial1 to communicate via TTL (5V) serial on pins 0 (RX) and 1 (TX). Serial is reserved for USB CDC communication. For more information, refer to the Leonardo getting started page and hardware page."
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
e14 Contributor
in reply to Jan Cumps
Cancel
Vote Up
+1
Vote Down
Sign in to reply
More
Cancel
e14 Contributor
Cancel
Vote Up
+1
Vote Down
Sign in to reply
More
Cancel
in reply to e14 Contributor
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
e14 Contributor
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
e14 Contributor
Cancel
Vote Up
+1
Vote Down
Sign in to reply
More
Cancel
e14 Contributor
Cancel
Vote Up
+1
Vote Down
Sign in to reply
More
Cancel
Comment-
e14 Contributor
Cancel
Vote Up
+1
Vote Down
Sign in to reply
More
Cancel
