Legacy Personal Blogs Arduino | Tutorial 3 | Serial Communication
  • Author Author: oksbwn
  • Date Created: 2 Jun 2016 6:00 AM Date Created
  • Views 2941 views
  • Comments 12 comments
  • ardbeginner
  • arduino_tutorials
  • arduino_tutorial
  • serial communicat
  • arduino serial programming.
oksbwn
oksbwn
2 Jun 2016
    e14 Contributor over 10 years ago in reply to Jan Cumps +1
    Jan Cumps Apparently, a reference to Serial in an if or while argument context evaluates to true if the specified serial port is available else there is a permanent/temporary error. There must be something…
    Ok, Jan Cumps earned the "King for the Day" title. I've been busy cleaning up my own mess (one of those "no good deed goes unpunished" stories). King of which country? How about the USA? Stay longer. The…
    Kings don't need a freakin' nomination. Just show up with your 3 dragons and legions of unsullied.
    Jan Cumps over 10 years ago
    Are you sure that the code
    if (Serial) {
      // communicate
    makes sense in the video? Isn't Serial always different from 0, because it's a static object that has a non-zero address? even if Serial.begin(9600) fails?
    Jan Cumps  Apparently, a reference to Serial in an if or while argument context evaluates to true if the specified serial port is available else there is a permanent/temporary error.  There must be something hidden in the compilation/interpreter that treats Serial special.  An if( Serial.isConnected() ) would be better.  Secrets are bad engineering practices but what can you do?  I cannot find any documentation of the static Serial object other than what's in the arduino.cc API.  Have you?
    To guard against a single spurious failure instance, I use this in setup() instead of the if-statement for Serial applications:
    int count_down = 3;
    while( ! Serial ) {
          // Sleep 1 second if not yet ready.
          delay( 1000 );
          // Tried the maximum allowed times already?
          if( count_down-- < 1 ) {
               // Tried 3 seconds to get the serial connection ready - giving up.
               // Timeout error processing goes here
    Jan Cumps over 10 years ago in reply to e14 Contributor
    The compiler is a standard c++ compiler and the linker is also a known one. So whatever the Serial library does must be a c++ construct.
    The source for the System class is open, so we can have a look ourselves. Let's do that.
    The first who finds it is king for a day...
