Legacy Personal Blogs Automatic Arduino Garden-Watering Project
  • Author Author: sasquatch84
  • Date Created: 7 Aug 2017 4:35 PM Date Created
  • Views 2229 views
  • Comments 7 comments
  • gogreench
sasquatch84
sasquatch84
7 Aug 2017
This is the first entry of my first project since joining here.  I work a lot and would like to have my garden watered by my Arduino.  I want the water to turn on every morning at the same time for the same duration.
As far as parts go, I have an adafruit water valve, 4 module relay, Arduino Uno for prototyping and a nano for the finished product.
It appears my first job is to figure out how to make the Arduino activate the solenoid at the same time.  I could ise a clock of some kind, but I could also have it turn on with the rising of the sun.
Both ideas seem like they are possible for my level of skill.  Decisions, decisions.
  • ntewinkel
    ntewinkel over 9 years ago +2
    A few years ago I built a similar watering setup for my greenhouse, but using pumps. Mine has 2 relays - 1 for the water pump, and 1 for a fertilizer pump. It would run the fertilizer pump at the start…
    dougw over 9 years ago +1
    Cool project. It will be interesting to watch it develop. Be sure to ask questions here if you run into snags. Thanks for sharing.
    DAB over 9 years ago +1
    I suggest you start small and build up capability as you get experience with the project. DAB
  • ntewinkel
    It would run the fertilizer pump at the start of the watering cycle to inject fertilizer in with the water, and shutting the fertilizer off early so that none of it was left in the lines (to avoid algae and such).
    The timing doesn't have to be accurate, so the software just relies on the internal clock. That seemed to stay close enough on time that I didn't notice any deviation throughout the watering season.
    I use 120v (not really safe for beginners) but it can be done with lower safer voltages too if you choose 12v pumps, for example.
    I originally had much bigger plans, like tracking sunlight, humidity, temperature, soil moisture, and the idea was to only water the plants when the soil moisture was down to a certain point. Ultimately I ran into issues with sensor numbers being unreliable, likely due to wire lengths, so I settled for having it just be a timer.
    I like the water valve you mentioned - it sounds like you could use the same 9v supply to run the Arduino as well as open the valve. And no need for a water barrel and pump!
    Let me know if you want the source code for that, I'd be happy to share. I don't have schematics or anything, but it's really just as simple as "connect pin A to relay 1, connect pin B to relay 2). And you don't even need relay2. It was mostly unused in my setup for several years. In any case, it might give you some starting ideas.
    Cheers,
    -Nico
  • sasquatch84
    sasquatch84 over 9 years ago in reply to ntewinkel
    I'd love to see the sketch!
  • ntewinkel
    ntewinkel over 9 years ago in reply to sasquatch84
    Hi Clinton,
    So sorry this completely slipped my mind for a few weeks!
    I've uploaded it: greenhouse_water_fertilizer_basic.ino
    It's not super accurate for time, but by the 80/20 rule works plenty well enough image
    At quick glance it looks like the start time is offset by the run times, but you could adjust the wait time to a number that subtracts the run times.
    Cheers,
    -Nico
  • ntewinkel
    Hi Clinton,
    Cheers,
    -Nico
