Legacy Personal Blogs Automatic Arduino Garden-Watering Project
  • Author Author: sasquatch84
  • Date Created: 7 Aug 2017 4:35 PM Date Created
  • Views 2230 views
  • Comments 7 comments
  • gogreench
sasquatch84
sasquatch84
7 Aug 2017
This is the first entry of my first project since joining here.  I work a lot and would like to have my garden watered by my Arduino.  I want the water to turn on every morning at the same time for the same duration.
As far as parts go, I have an adafruit water valve, 4 module relay, Arduino Uno for prototyping and a nano for the finished product.
It appears my first job is to figure out how to make the Arduino activate the solenoid at the same time.  I could ise a clock of some kind, but I could also have it turn on with the rising of the sun.
Both ideas seem like they are possible for my level of skill.  Decisions, decisions.
  • ntewinkel
    ntewinkel over 9 years ago +2
    A few years ago I built a similar watering setup for my greenhouse, but using pumps. Mine has 2 relays - 1 for the water pump, and 1 for a fertilizer pump. It would run the fertilizer pump at the start…
    dougw over 9 years ago +1
    Cool project. It will be interesting to watch it develop. Be sure to ask questions here if you run into snags. Thanks for sharing.
    DAB over 9 years ago +1
    I suggest you start small and build up capability as you get experience with the project. DAB
  • adiclepcea
    adiclepcea over 9 years ago
    I did a project that might help you with some ideas.
    It uses however an older version of Arduino IDE.
    Arduino Multiple Timer. Day Based and Alarm Based: 3 Steps
    With it you can use up to 6 timers and set up the period they run for and also choose the days of the week when they run.
    It uses a DS1307 timer but other compatible timers have been used for this project with success.
    HTH.
  • adiclepcea
    HTH.
