Legacy Personal Blogs Block Design
  • Author Author: oakadin
  • Date Created: 10 Jul 2013 2:14 PM Date Created
  • Views 510 views
  • amplifer
Block Design
oakadin
oakadin
10 Jul 2013
So far im working on the block arrangement for the amp.
Using a pre amp with all tone and volume controls to keep it simple untill the amp is fully working.
then from the pre amp to a 30w amp and then finally into a 2- channel speeker protector to reduce clicks and distortion as much as possible.
main problem will be finding the best way to get power to all 3 pcb as efficiant as possible, i will check into this more later today maybe relay board
Transformers to each pcb but unsure on if thats possible.
better get reading.
