Legacy Personal Blogs C&C: The Wimpy Robot Bumper Class
  • Author Author: alanmcdonley
  • Date Created: 25 Jun 2016 2:05 AM Date Created
  • Views 498 views
  • python-control-c
  • python-callbacks
  • python-threads
  • bumpers
  • python-class
alanmcdonley
alanmcdonley
25 Jun 2016
Here is the Bumper Class with polling thread to read the bumpers asynchronously from the consumer (test main() in the same file) and my control-c handler that can call a class object's cancel function to kill the thread and clean up: (I have the feeling I don't need the global statements.)
[code]
# myPyLib.py   SUPPLIMENTAL PYTHON FUNCTIONS
# v0.1 19June2016
import time
import sys
import signal
# ######### CNTL-C #####
# Callback and setup to catch control-C and quit program
_funcToRun=None
def signal_handler(signal, frame):
  print '\n** Control-C Detected'
  if (_funcToRun != None):
     _funcToRun()
  sys.exit(0)
# Setup the callback to catch control-C
def set_cntl_c_handler(toRun):
  global _funcToRun
  _funcToRun = toRun
  signal.signal(signal.SIGINT, signal_handler)
[/code]
[code]
#!/usr/bin/python
# bumbersClass.py   BUMPERS SENSOR CLASS
import PDALib
import myPDALib
import myPyLib
import time
import sys
import threading
class Bumpers():
  # CLASS VARS (Avail to all instances)
  # Access as Bumpers.class_var_name
  pollThreadHandle=None   # the SINGLE read sensor thread for the Bumpers class
  tSleep=0.033            # time for read_sensor thread to sleep after each read op
  # Bumpers are on the Pi Droid Alpha MCP23S17 DIO expander
  # Wired to use internal pull-up power of the MCP23S17
  # Bumper value is negative logic - 0 means bumper activated, normal 1
  LeftBumperDIO=18
  RightBumperDIO=17
  RearBumperDIO=16
  # Allowable Bumpers.state values
  NONE     = 0
  # Single bumpers
  LEFT     = 1
  RIGHT    = 2
  REAR     = 4
  # Combinations
  FRONT    = 3
  LEFTREAR = 5
  RIGHTREAR= 6
  ALL      = 7
  # Not possible
  UNKNOWN  = 8
  # THE STATE OF EACH BUMPER and the combined BUMPERS state
  # (class vars because there are only one physical bumper)
  # note: can get rid of left(), right(), rear() methods by using these vars direct
  leftState= UNKNOWN
  rightState=UNKNOWN
  rearState= UNKNOWN
  state=     UNKNOWN  #0,1=L,2=R,3=L+R(front),4=Rear,...
  # use to print Bumper.state var
  bumperStrings=["NONE", "LEFT", "RIGHT", "FRONT", "REAR",
               "LEFTREAR", "RIGHTREAR", "ALL", "UNKNOWN"]
  # end of class vars definition
  def __init__(self):
    # SINGLETON TEST
    if (Bumpers.pollThreadHandle!=None):
        print "Second Bumpers Class Object, not starting pollingThread"
        return None
    # Set Bumper DIO channels as input for now
    PDALib.pinMode(Bumpers.LeftBumperDIO, PDALib.INPUT)
    PDALib.pinMode(Bumpers.RightBumperDIO,PDALib.INPUT)
    PDALib.pinMode(Bumpers.RearBumperDIO, PDALib.INPUT)
    # Set internal pull-ups on bumper channels
    PDALib.setDioBit( PDALib.DIO_GPPU, 8 )  # set LeftBumper  pin 16 pull-up
    PDALib.setDioBit( PDALib.DIO_GPPU, 9 )  # set RightBumper pin 17 pull-up
    PDALib.setDioBit( PDALib.DIO_GPPU, 10 ) # set RearBumper  pin 18 pull-up
    # threading target must be an instance
    Bumpers.pollThreadHandle = threading.Thread( target=self.pollBumpers,
                                               args=(Bumpers.tSleep,))
    Bumpers.pollThreadHandle.start()
  #end init()
  # BUMPER THREAD WORKER METHOD TO READ BUMPERS
  def pollBumpers(self,tSleep=0.01):
    print "pollBumpers started with %f" % tSleep
    t = threading.currentThread()   # get handle to self (pollingBumpers thread)
    while getattr(t, "dorun", True):  # check the dorun thread attribute
      self.read()
      time.sleep(tSleep)
    print("dorun went false. Stopping pollBumpers thread")
  def read(self):  #READ THE BUMPERS - can be used as poll or directly
      Bumpers.leftState= Bumpers.LEFT - Bumpers.LEFT * \
     PDALib.digitalRead(Bumpers.LeftBumperDIO)
      Bumpers.rightState= Bumpers.RIGHT - Bumpers.RIGHT * \
       PDALib.digitalRead(Bumpers.RightBumperDIO)
      Bumpers.rearState=  Bumpers.REAR - Bumpers.REAR * \
    PDALib.digitalRead(Bumpers.RearBumperDIO)
      Bumpers.state = Bumpers.leftState + Bumpers.rightState + Bumpers.rearState
      return Bumpers.state
  def status(self):
  def left(self):
    return Bumpers.leftState
  def right(self):
    return Bumpers.rightState
  def rear(self):
    return Bumpers.rearState
  def toString(self,bumperState=UNKNOWN):
    if (bumperState==Bumpers.UNKNOWN):
       bumperState= Bumpers.state
    return Bumpers.bumperStrings[bumperState]
  def cancel(self):
     print "bumpers.cancel() called"
     self.pollThreadHandle.dorun = False
     myPDALib.PiExit()
# ##### BUMPER CLASS TEST METHOD ######
# creates two instances, only the first should start the read() thread
# the first time through the main() while loop, the sensors may not have been read yet
#     so bumpers.status() and each bumper may have a value of 8/UNKNOWN
def main():
  # note: lowercase bumpers is object, uppercase Bumpers is class (everywhere in code)
  bumpers=Bumpers()  #create an instance which starts the read bumpers thread
  bumpersNoThreadStart=Bumpers()  # Test a second instance of class
  myPyLib.set_cntl_c_handler(bumpers.cancel)  # Set CNTL-C handler
  while True:
      print "\n"
      print "bumpers.state: %d %s" % (bumpers.status(), bumpers.toString())
      print "left():%d  rear():%d  right():%d" % (
  bumpers.left(),
  bumpers.rear(),
  bumpers.right() )
      time.sleep(1)
  #end while
if __name__ == "__main__":
    main()
[/code]
