Legacy Personal Blogs Call REST API using JAVA on Raspberry Pi
  • Author Author: oksbwn
  • Date Created: 8 Jun 2017 3:00 PM Date Created
  • Views 1131 views
  • tutorial
  • getting started with pi
  • java on raspberry pi
  • raspberry pi
  • getting started
  • rest api raspberry pi
  • rest api
oksbwn
oksbwn
8 Jun 2017
This video is around Raspberry Pi to showcase the usage of Raspberry Pi in IOT projects and that's using JAVA. This is going to be a series of video including Sensor interfacing using pi4J, REST API usage with JAVA, MQTT usage with JAVA and finally adding all to the same project and running over Raspberry Pi. In the last video, we saw how to interface DS18B20 1 wire temperature sensor with Raspberry Pi by using JAVA. If you have not checked it out you can do that and for that, I have provided the link down below in the description. This video is the 2nd in the series where we will see how to publish or send sensor data using REST API to cloud. And in this, we are using ThingSpeak as cloud service to publish data. HTTP calls for REST API are done using Unirest lightweight HTTP client library. In the next video, we will do the same by using MQTT.
Links :
Github Repo: http://bit.ly/2sxXweP
Download Unirest Library: http://bit.ly/2j32blF
Unirest Website: http://bit.ly/2rFQ2t3
Unirest Jar Download (With Dependencies): http://bit.ly/2sAbhul
First Part (DS18B20 Interfacing with Raspberry Pi using JAVA): http://bit.ly/2rxd1WK
Java Application on Pi Playlist: http://bit.ly/2eB1O2K
