Legacy Personal Blogs Can I assume that a “Rail to Rail” Op-Amp will have this feature on both the input and output?
  • Author Author: jhayden
  • Date Created: 28 Dec 2009 2:13 PM Date Created
  • Views 683 views
  • ic
  • op-amp
  • rail_to_rail
jhayden
jhayden
28 Dec 2009
            Not necessarily!  Op-Amps can have the “Rail to Rail” feature on the input only, output only, or both.  Different circuit parameters can also affect just how close to the rail the Op-Amp can go (for example, the load current can limit the output voltage of an op-amp with rail to rail output).  Be sure to check the manufacture’s datasheet to ensure its configuration will match your requirements.
