Legacy Personal Blogs Chris Pinter's 10 steps to researching your patentable idea.
  • Author Author: Chris_Pinter
  • Date Created: 10 Jan 2014 6:00 PM Date Created
  • Views 1104 views
  • Comments 5 comments
  • market
  • innivation
  • Technology
  • development
  • reseach
  • patents
Chris_Pinter
Chris_Pinter
10 Jan 2014
Doing market research for a new innovation has a number of inherent risks related to intellectual property exposure. You need to talk about your idea but once you do so you expose your idea to the public, competition and as a result you risk not getting a patent awarded.
On one hand you cannot talk about your idea because once you do so the information becomes public knowledge and therefore not patentable. Someone could also steal your idea and in todays global market this is a real threat. Patents are important as you have the court system to help protect your idea from patent infringement. However, you can only patent an idea if it is a non-obvious [1] extension of the prior art [2] or you can prove it is something brand new.
On the other hand you need to do market research to establish value for the innovation. If the idea is really bad it has no value and no one will want to buy it. Why would anyone want to steal a patent with no value? People file for patents all the time without doing adequate market research. You could spend a lot of money in patenting an idea that no one needs or cares about. It has been done in the past and is still being done today.
popular mouse trap
Case in point, the mousetrap has been invented over 4400 times and continues to be patented. Each year over 400 new patents are created for the mousetrap. [3] This brings up two points.
      1. 1. It is possible to patent an idea without doing market research. (My advice; don’t do it!)
    1. 2. Even if you do patent your idea. Someone else can still get a similar patent and compete with you. Take a look at the mousetrap example. 400 people each year are hoping to sell a mousetrap without truly understanding that the market does not need yet another mousetrap!
So you need to establish a need to prove value. You need to talk to people about your idea to ensure your patent will produce a return on investment. The dilemma is how do you ask for people’s opinions without exposing your idea?
Here is a step-by-step process to avoid exposing your intellectual property while you do market research.
1. Make a list of potential Patentable Features.
Make a list of all of the features of your patentable idea. Identify each element that makes it worthy of a patent. The primary features will uniquely identify how the innovation works. Secondary features will address usability and generally help in the understanding or use of the primary features.
2. Research the Prior Art.
Research all of the publicly available information on your subject matter. You want to get as much information on the prior art as you can. Don’t forget to check for prior patents. It is a good idea to review all similar patents. These are great sources of information and can help you if you want to improve on an existing idea. Many people enlist the help of a patent lawyer to do this search. Enlisting the services of a patent lawyer is very thorough and will give you everything. However outlaying large amounts of cash to investigate an idea should be avoided.
3. Make a list of Prior Art Features.
Make a list of all of the key points that are obvious and common knowledge concerning your subject matter by using the information you collected about the prior art. This list will be very useful as you do your research. When you are finished you will have a quick list of everything there is to know about the subject matter.
4. Compare Patentable Features Against Prior Art Features.
Check your Patentable Features list you created in step 1 against the Prior Art Features you created in step 3. Make sure your Patentable Features list does not include anything from the Prior Art Features list. Make sure your idea does not contain obvious information or information that is in the public domain. Remember, if the public already know about the innovation you cannot get a patent awarded. So make sure your Patentable Features list does not contain anything that is already public knowledge.
5. Secure your Patentable Features list!
So now you have identified all of the critical ideas about your innovation that you cannot talk about. Hold the list of Patentable Features very close, lock it in a safe and do not share this information.
6. Create a Topic of Discussion.
Using your list of Prior Art Features describe your “topic of discussion” so people have an idea about what problem you want to address. If you only talk about the items outlined on your list of Prior Art Features you can freely talk about everything on that list. This list contains everything that is already common knowledge and is already in the public domain.
NOTE: If the information is already in the public domain you can freely talk about it.
7. Verify your Topic of Discussion.
Ask someone you know and trust to review the description and ask them if they can guess at the potential patentable idea. If someone can guess at what you are doing then it could be considered obvious and you will need to hire a good lawyer to prove it is not obvious. Ideally the people you ask will not be able to guess at your idea.
8. Research your Topic of Discussion.
Now you have just created a description of something that people can talk about. You should be able to ask questions related to needs and wants without having to tell too much about your solution. Ideally the people you ask will tell you about the needs that your solution will solve.
9. Its OK to say NO.
patent
Remember, It is ok to tell people that you cannot tell them everything about your idea. Tell them you cannot share more information because you need to be able to apply for a patent and cannot share more information at this time. This is a fair statement and people should respect this position.
10. Non-Disclosure Agreements.
A non-disclosure agreement (NDA) is a legal document that is made between two parties that promise to not talk about or disclose confidential or propriety information to anyone outside of the agreement. Many industries including the technology development industry use this type of agreement to allow the discussion of “patentable ideas” to be shared with trusted partners.
They are great when working with other developers but not adequate when dealing with the general public. An NDA will have several enforceable repercussions outlined in case someone breach’s the contract. You need to be able to track all those who have signed the agreement, and be able to clearly identify who breached the contract in order to enforce the terms of the contact. This is impossible when you have asked hundreds or thousands of people to sign a general NDA.
If you need more information that this article has not covered you most likely need a more specific answer and should contact a qualified patent lawyer before you expose your ideas to the public.
______________
Further Reading
[1] http://en.wikipedia.org/wiki/Inventive_step_and_non-obviousness
[2] http://www.tms.org/pubs/journals/jom/matters/matters-9106.html
[3] http://www.uh.edu/admin/engines/epi1163.htm
- See more at: http://www.pinterec.ca/chris-pinters-10-steps-researching-patentable-idea/#sthash.tMU0mj8S.dpuf
  • Chris_Pinter
    Chris_Pinter over 12 years ago in reply to DAB +1
    HA. DAB, i am not really talk about the patent process...but good to know that it is indeed a process. Maybe you coudl provide a blog for everyone on what the patent process is like. I did it and it is…
  • johnbeetem
    johnbeetem over 12 years ago
    JMO/IANAL/YMMV
    As of 16 March 2013, the USA switched from a "first to invent" system to a "first to file" system.  This means that if you come up with a great idea and don't publish or patent it right away, someone else could come up with the same idea later and if they file a patent first then you can no longer use your idea without infringing on the later one.  Insane?  Yes.  The law?  Apparently so.
    If you publish your idea in any form, you get a one year grace period in which to file a patent.  Once it's published, it immediately becomes prior art, so if anyone comes up with the same idea they cannot patent it.  Once the year is up, you can't patent it either and your Gendanke becomes frei.
    My advice (IANAL) is to publish everything as soon as possible to protect yourself from someone else filing first.  However,
    for real legal advice you need to see a real lawyer.  My information is from the Wikipedia page on the Leahy-Smith America Invents Act.
  • Chris_Pinter
    Chris_Pinter over 12 years ago in reply to johnbeetem
    This is the way it is in MOST countries.  The US is way...way...way behind the times when it comes to FAIR patent law.  The US patent system is set up to exploit inventors ...now it is fair. First to patent is the best....it eliminates the scum who fabricate data to " prove" they were the first.
    MY advise remains the same.  Do not patent your idea until you have something to patent.  By patenting an idea that is NOT WELL RESEARCHED...someone else will start with you published patent and continue research with a better product.
    Don't be a fool..research your idea...keep your ideas close.... and when you have a gem then go and spend the money for a patent.
    CHris Pinter
    www.pinterec.ca
  • Chris_Pinter
    CHris Pinter
    www.pinterec.ca
