Legacy Personal Blogs Color Sensor how-to.
  • Author Author: timswift
  • Date Created: 19 Nov 2014 10:32 PM Date Created
  • Views 829 views
  • mega
  • light
  • led
timswift
timswift
19 Nov 2014
Recently I built a color sensor and thanks to @Paul and @Peter Oakes i got the code to work. so i thought i would share it with you.
Parts i used:
(1) Arduino Mega
(1) 10K ohm resister
(4) 220 ohm resister
(1) Red LED
(1) Green LED
(1) Blue LED
(1) White LED
(1) Light sensitive resister
And the schematic:
Finely the code:
int sensorPin = A0;
  int red = 0;
  int green = 0;
  int blue = 0;
  int led1 = 2;
  int led2 = 3;
  int led3 = 4;
  int led4 = 8;
  int val1 = -12;//Use this to ajost the red value
  int val2 = -4;//Use this to ajost the green value
  int val3 = -18;//Use this to ajost the blue value
  int sensorValue = 0;
void setup() {
  pinMode(led1, OUTPUT); //Red LED
  pinMode(led2, OUTPUT); //Green LED
  pinMode(led3, OUTPUT); //Blue LED
  pinMode(led4, OUTPUT); //Detecshin LED
  Serial.begin(9600);
void loop() {
  digitalWrite(led1, HIGH);
  sensorValue = analogRead(sensorPin);
  red = (sensorValue / 10) + val1;
//  Serial.print("red =");
//  Serial.println(red);
delay(50);
  digitalWrite(led1, LOW);
  digitalWrite(led2, HIGH);
  green = (sensorValue / 10) + val2;
//  Serial.print("green =");
//  Serial.println(green);
delay(50);
  digitalWrite(led2, LOW);
  digitalWrite(led3, HIGH);
  blue = (sensorValue / 10) + val3;
// Serial.print("blue =");
// Serial.println(blue);
delay(50);
digitalWrite(led3, LOW);
if(blue > 13 and blue < 17 and green > 13 and green < 17 and red > 13 and red < 17){
Serial.println("whight");
digitalWrite(led4, HIGH);
delay(1000);
else{
digitalWrite(led4, LOW);
This code turns on the detection LED wen a green object is held over the sensor.
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago +1
    Good job and thanks for sharing
    DAB over 11 years ago +1
    Good post Tim. DAB
    Good post Tim.
