Legacy Personal Blogs Crawling Worm Robot
  • Author Author: dubbie
  • Date Created: 11 Dec 2020 5:46 PM Date Created
  • Views 3553 views
  • Likes 11 likes
  • Comments 9 comments
  • worm robot
  • crawling robot
Crawling Worm Robot
dubbie
dubbie
11 Dec 2020
I have seen these crawling worm robot kits around for some time and always thought they looked interesting, so while I was buying other people Christmas presents, I bought one for myself as well.
It has some neat design features to make it simpler to construction and low cost. The battery compartment comes with a built-in switch. Not a good picture below  but you can just about see the lever that you turn to make a contact with the other battery terminal.
It probably took about an hour to put together and it does have some very small screws and some fiddly assembly sequences. Additionally the instructions were in Chinese but by carefully viewing the diagrams on the leaflet and overcoming my fat fingers and less that perfect eyesight I managed to put it together.
A fascinating motion. It truly zips along at some speed.
Technically, it is not a robot as it does not have any sensors or even a controller, but I think it would be relatively easy to add an Arduino of some description, plus a sensor, and then it will be able to interact with it's environment. I wonder if I can connect two or more together to make a much longer worm?
Dubbie
    beacon_dave over 5 years ago +5
    Is this 'bait' for your cat detector ? genebren this type of action may drive your whistle bellows for your Mr Machine
    DAB over 5 years ago +4
    Nice build. It would cause my dog to attack it immediately. She likes to chase anything that moves. DAB
  • ntewinkel
    ntewinkel over 5 years ago +3
    Aahaha that's awesome! Is the worm action used to propel it forward, or is all of that just in the drive wheels? -Nico
    Nice build.
    dubbie over 5 years ago in reply to DAB
    DAB,
    Well, it would give the dog some fun, one at least!
    Dubbie
    DAB over 5 years ago in reply to dubbie
    I used an RC car to tease my Jack Russel.
    She would attack it until it stopped moving.
    All I had to do was make it twitch and she would pounce on it again.
    She eventually took most of a tire off.
