Legacy Personal Blogs Disabling Touch in Raspbian for the Adafruit 2.4" PiTFT
  • Author Author: andywest
  • Date Created: 30 Apr 2018 10:46 PM Date Created
  • Views 1379 views
  • pitft
  • touch screen
  • raspbian
andywest
andywest
30 Apr 2018
I've been working on a Raspberry Pi-based handheld that requires a 2.4" screen, so I decided to try Adafruit's PiTFT LCD. This project doesn't require touch, and I started having weird issues with the resistive input that were bogging down the CPU and making the UI unusable.
I searched fruitlessly for a simple way to disable touch in Raspbian Stretch. Adding disable_touchscreen=1 to config.txt didn't work, presumably because it's screen-specific.
I finally came up with a solution by combining information from two sources: Adafruit's manual installation instructions, which revealed the name of the module, and a Stack Overflow answer that mentioned raspi-blacklist.conf.
Here's how I did it:
  1. Start the device running Raspbian.
  2. Go to the command line (e.g., open a terminal window).
  3. Run sudo nano /etc/modprobe.d/raspi-blacklist.conf
  4. Add the line: blacklist stmpe_ts
  5. Exit nano with Ctrl+X, and follow the prompts to save
  6. Reboot
This was all I needed to permanently disable touch. Hopefully it helps somebody out there.
    genebren over 8 years ago +1
    Andy, Nice find and fix. Gene
    Andy,
    Nice find and fix.
    Gene
