Legacy Personal Blogs Drones Vs. Drones
  • Author Author: plowe
  • Date Created: 25 Jan 2016 2:06 PM Date Created
  • Views 7331 views
  • Comments 59 comments
  • multi rotor
  • eagle
  • emerging_tech
  • multi-rotor
  • drone_news
  • multi rotor copter
  • drone_tech
  • drones
  • quadcopter
Drones Vs. Drones
plowe
plowe
25 Jan 2016
(Robotic falconry via Wired.Com)
The rise of Quadcopters and Drones has been a pretty quick one. You only have to look back to Christmas and see the numerous gadget shops that offered all sorts of cheap, off of the shelf remote controlled quadcopters to see that the technology has captured the imaginations of thousands of people around the world.
But what happens when that technology then needs to be kept in check? What happens, if that technology is being used for evil instead of good? (Insert your own version of 'with great power comes great responsibility' anecdote here). Well, it appears that the answer is to fight fire with fire...or more accurately Drones with Drones. Mechanical engineers from Michigan Tech University have developed an anti-drone drone that has abilities Spiderman himself would be proud of.
The weapon of choice is a giant net that not only fires at the offending drone, but remains attached for the attacking drone to drag its prey off to pretty much where ever it chooses. Mo Rastgaar, associate professor of mechanical engineering, said "It's like robotic falconry. What makes this unique is that the net is attached to our catcher, so you can retrieve the rogue drone or drop it in a designated, secure area."
Effective from up to 40 feet away, the drone catching net brings its target down upon impact and the idea of being able to carry it off means any intel that the drone has collected (as long as it's stored locally) is reclaimed and, in worse case scenarios, if the Drone is armed with explosives it can be brought down in a designated safe zone to reduce casualties and/or damage to surrounding buildings.
It's not the first attempt at using drones to police other drones,  in August Boeing unleashed their ground to air laser drone defense system which pretty much does what it says on the tin- spots a drone, fires laser, drone is dead...scary stuff. Others seem to be turning to more tech related methods to stop unwanted attention from the sky in the form of geo-fencing systems which prohibit a drone from flying in places by using GPS.
With rumors that the UK may be under threat from drones carrying explosives (Disclaimer: not sure just how true that is or how big a risk it is- please don't panic and buy anything to shoot down drones) it appears that this rise in anti-drone tech could be the start of an influx of tech based defenses to protect people from miniature aerial threats...
However, seeing as bears and even an eagle has been reported to have taken drones out then maybe a more natural solution could be considered- everyone is familiar with the resident Eagle at the Wimbledon Tennis Tournament which is employed to keep pigeons off of the courts; could we soon see homes and estates employing birds of prey to ward off drones?
Cue an epic battle in the skies that will ring throughout the ages: Drones Vs. Eagles...think I'll stay indoors for that one.
This video is unavailable.
  • Dudley
    Dudley over 10 years ago in reply to gadget.iom +3
    We have a similar regulation here . It is, if anything, even more unwieldy and more legalese than the US one. I don't know about the states, but here there's a looming crisis. Air regulation relies on…
  • Problemchild
    Problemchild over 10 years ago in reply to mcb1 +3
    Hi Mark, yeah 500ft isn't that high for a drone to achieve. You've go to wonder why you want to do that though especially on some regular habitual basis as above 50 ish feet you can't hear it and at 500ft…
  • crjeder
    crjeder over 10 years ago in reply to Dudley +3
    With "Drones" which weight much less than a wild goose they are a much smaller problem for aviation than the press makes us believe. Rotors of rescue helicopters can chop small trees easily, there is no…
    its awesome
  • Dudley
    Dudley over 10 years ago in reply to e14 Contributor
    Catching things in the air with a giant net?
    Like this you mean?
    (Warning, contains bad language)
    Begs the question, what happens to the person living underneath the drone that's been entangled. And whose liable for any damage? The drone owner? Or the person that wrapped the drone in a net?
    mcb1 over 10 years ago in reply to Dudley
    Airways recognised the issues becoming bigger than a plague and kicked off this website
    The rules they refer to is
    RPAS, UAV, UAS, Drones and Model Aircraft
    A bit more web designer intelligence is needed though
    Click NO on this and get the NO response ... but you have to search for the 'rules' (rather than make the button a link.)
    A correct answer get s you to the next question.
    It won't stop the problem but at least the rules give Proper Operators the means to go about 'commercial' flying.
  • Problemchild
    Can't  drone operators find some where else to fly other than airports ...They used to Ironically after paranoia laws come in they will probably be edged out into similar  areas as planes. Once again regulations to keep stupid people in control ..only problem they dont/can't read
    mcb1 over 10 years ago in reply to Problemchild
    It isn't actually the "airport' but more the flight paths.
    On some airports this is directly inline with the Airport, but at many there are turning areas and other areas for 'missed approach', etc.
    For most commercial aircraft the closest turn onto the runway is 9nm so that is roughly a 22 mile radius of an Airport.
    In Chch that covers the entire city.
    For any other non city/built-up area 500ft above ground is the lowest allowable limit, and it isn't hard to get a drone to 500ft.
  • Problemchild
    Problemchild over 10 years ago in reply to DAB
    We don't see many of those. Even when one makes global news we don't see that many except maybe that one that went out of control at the ski event.
    We should be more circumspect and not believe everything we are told after all these are the same people who believe  that some kid putting the guts of a clock into a box makes him a terrorist.
  • Problemchild
    Hi Mark, yeah 500ft isn't that high for a drone to achieve. You've go to wonder why you want to do that though especially on some regular habitual basis as above 50 ish feet you can't hear it and at 500ft(especially some distance away) you can't even see it (white drone on a white cloudy sky ) except for maybe the lights.
    From a drone photography point of view most things you would want to photograph would look like dots or at least rather uninteresting from that height.
    That said I'm sure the world is full of sufficiently retarded and ignorant people....not sure the law however can help us here as a mass cull on them would bump off too many voters for our politicians image
  • Problemchild
    A lot of them now have video from onboard so that isn't an issue.
    Even the smaller versions have GPS, so again a lack of real control.
    500ft is not that high if you are looking for Aerial photos and perhaps doing some form of panoramic view.
  • Problemchild
    Yeah the GPS isn't that useful except where integrated into some telematics system and really FPV(First Person Video/Vision) and then you can really go mad I saw one going round Yorkshire on a 40 mile round trip which is really clever but mad as it went past some RAF bases etc.
    Re 500 ft if I took a pic of your house or you or your trees from 500 ft they would look flat and boring so from a practical point of view why do it  which was my point.
    Obviously there are folk who need to take the "Big Picture" but they are legitimate(probably paid to survey or some such)  and really not a problem as they would be following the rules and or exceptions. If there was a building that looked really cool at many hundreds/thousands of feet then I would be more woried about crashing my plane in to the big building than some piddly drone
