Legacy Personal Blogs Drones Vs. Drones
  • Author Author: plowe
  • Date Created: 25 Jan 2016 2:06 PM Date Created
  • Views 7392 views
  • Comments 59 comments
  • multi rotor
  • eagle
  • emerging_tech
  • multi-rotor
  • drone_news
  • multi rotor copter
  • drone_tech
  • drones
  • quadcopter
Drones Vs. Drones
plowe
plowe
25 Jan 2016
(Robotic falconry via Wired.Com)
The rise of Quadcopters and Drones has been a pretty quick one. You only have to look back to Christmas and see the numerous gadget shops that offered all sorts of cheap, off of the shelf remote controlled quadcopters to see that the technology has captured the imaginations of thousands of people around the world.
But what happens when that technology then needs to be kept in check? What happens, if that technology is being used for evil instead of good? (Insert your own version of 'with great power comes great responsibility' anecdote here). Well, it appears that the answer is to fight fire with fire...or more accurately Drones with Drones. Mechanical engineers from Michigan Tech University have developed an anti-drone drone that has abilities Spiderman himself would be proud of.
The weapon of choice is a giant net that not only fires at the offending drone, but remains attached for the attacking drone to drag its prey off to pretty much where ever it chooses. Mo Rastgaar, associate professor of mechanical engineering, said "It's like robotic falconry. What makes this unique is that the net is attached to our catcher, so you can retrieve the rogue drone or drop it in a designated, secure area."
Effective from up to 40 feet away, the drone catching net brings its target down upon impact and the idea of being able to carry it off means any intel that the drone has collected (as long as it's stored locally) is reclaimed and, in worse case scenarios, if the Drone is armed with explosives it can be brought down in a designated safe zone to reduce casualties and/or damage to surrounding buildings.
It's not the first attempt at using drones to police other drones,  in August Boeing unleashed their ground to air laser drone defense system which pretty much does what it says on the tin- spots a drone, fires laser, drone is dead...scary stuff. Others seem to be turning to more tech related methods to stop unwanted attention from the sky in the form of geo-fencing systems which prohibit a drone from flying in places by using GPS.
With rumors that the UK may be under threat from drones carrying explosives (Disclaimer: not sure just how true that is or how big a risk it is- please don't panic and buy anything to shoot down drones) it appears that this rise in anti-drone tech could be the start of an influx of tech based defenses to protect people from miniature aerial threats...
However, seeing as bears and even an eagle has been reported to have taken drones out then maybe a more natural solution could be considered- everyone is familiar with the resident Eagle at the Wimbledon Tennis Tournament which is employed to keep pigeons off of the courts; could we soon see homes and estates employing birds of prey to ward off drones?
Cue an epic battle in the skies that will ring throughout the ages: Drones Vs. Eagles...think I'll stay indoors for that one.
This video is unavailable.
  • Dudley
    Dudley over 10 years ago in reply to gadget.iom +3
    We have a similar regulation here . It is, if anything, even more unwieldy and more legalese than the US one. I don't know about the states, but here there's a looming crisis. Air regulation relies on…
  • Problemchild
    Problemchild over 10 years ago in reply to mcb1 +3
    Hi Mark, yeah 500ft isn't that high for a drone to achieve. You've go to wonder why you want to do that though especially on some regular habitual basis as above 50 ish feet you can't hear it and at 500ft…
  • crjeder
    crjeder over 10 years ago in reply to Dudley +3
    With "Drones" which weight much less than a wild goose they are a much smaller problem for aviation than the press makes us believe. Rotors of rescue helicopters can chop small trees easily, there is no…
    mcb1 over 10 years ago in reply to Dudley
    Airways recognised the issues becoming bigger than a plague and kicked off this website
    The rules they refer to is
    RPAS, UAV, UAS, Drones and Model Aircraft
    A bit more web designer intelligence is needed though
    Click NO on this and get the NO response ... but you have to search for the 'rules' (rather than make the button a link.)
    A correct answer get s you to the next question.
    It won't stop the problem but at least the rules give Proper Operators the means to go about 'commercial' flying.
    DAB over 10 years ago in reply to Dudley
    Hi Dudley,
    I suspect that drone owners will be their own worst enemy in these regulation wars.
    Every time a drone interfers with an event, there will be more calls for limiting their assessibility to populated areas.
    As long as some users abuse the laws and risk public safety, there will be more rules and regulations imposed on their use.
  • Dudley
    We have a similar regulation here. It is, if anything, even more unwieldy and more legalese than the US one.
    I don't know about the states, but here there's a looming crisis. Air regulation relies on two basic premises
    A) If you mess up we'll throw the book at you and void any insurance you might have had, and
    B) maybe not let you fly again.
    Neither of these work though when the person in question is usually anonymous, and if told that they can't fly, will go somewhere else, and if their equipment is seized, they'll just buy a different drone.
    I think drone tech is really exciting, and has mountains of potential, but there is a real challenge with regulation. And it'll probably stay that way until there's a collision between a drone and a passenger airliner. And then, who knows?
    In the meantime, the near misses just keep happening.
  • gadget.iom
    gadget.iom over 10 years ago in reply to Dudley
    Dudley Nelson wrote:
    Begs the question, what happens to the person living underneath the drone that's been entangled. And whose liable for any damage? The drone owner? Or the person that wrapped the drone in a net?
    Is this bad-boy being enforced in the states?
    http://www.faa.gov/news/updates/media/20151213_IFR.pdf
  • Dudley
    Dudley over 10 years ago in reply to e14 Contributor
    Catching things in the air with a giant net?
    Like this you mean?
    (Warning, contains bad language)
