Legacy Personal Blogs ELEC2645 Project - Specification
  • Date Created: 13 Mar 2016 12:11 PM Date Created
  • Views 689 views
e14 Contributor
e14 Contributor
13 Mar 2016
ELEC2645 - Embedded Systems Project - 'Sensor-matic!'
The aim of the project is to create an interface between a distance and a temperature sensor and an LCD screen.
Project Aims and Objectives
Aims:
  • To develop a small, portable battery-powered distance/temperature sensor.
  • To read the sensor outputs frequently.
  • Display the sensors outputs on a Nokia 5110 LCD screen.
  • Provide a visual representations of the distance/temperature on the display.
  • Use an options menu to toggle various aspects of the hardware functionality (i.e. toggle the use of LEDs and sound).
  • Maximise the battery life by using as little power as possible.
Objectives:
  • The battery will be a PP3 9 V battery which is mounted onto the PCB.
  • The sensors will take 10 readings every second and average to minimise errors.
  • A timer will be used so that measurements are taken at intervals.
  • The Nokia 5110 library will be imported and used to display the value of the screen at every interval.
  • ‘IF Statements’ will be used to display the visual representation of the distance.
  • A 10 K Potentiometer will vary the selection of the options menu.
  • LEDs will light up depending on the distance (Green àààà
  • A Piezo will buzz on each iteration and buzz faster at increasing distance.
  • An efficient switching regulator will be used to minimise power-usage.
  • Sleep Modes will be used to save power.
Project Constraints/Components
Main Components:
  • Ultrasonic Distance Sensor (SRF02).
  • Temperature Sensor (TMP102).
  • Nokia 5110 LCD Display.
  • Powered by PCB-Mounted 9 V Battery (PP3).
  • Stepped Down using 9-t0-5 V Buck Converter (MC34062 & Associated Components).
  • Two-Layer PCB Board (100 mm by 80 mm).
Electronic Components:
  • 3mm LEDs (1x Red, 1x Green, 1x Yellow).
  • 1 kΩ Resistors (1206 Surface-Mount Package).
  • 2x Push Buttons – Change Menu Display & Invert Colour.
  • 1x Slide Switch (SPDT) – Power Supply Control.
  • Piezo Buzzer – Sounds at Regular Intervals.
  • 10 K Potentiometer – Change Menu Selection.
Project Specification
Specification:
  • The device will be powered by a single 9 V battery.
  • A 9 V-to-5 V Switching Regulator (MC34063) will be used to step-down the voltage.
  • There will be a red LED in parallel with the switching regulator to indicate powers on.
  • A TMP102 Temperature Sensor will be used.
  • A SRF02 Distance Sensor will be used.
  • A Nokia 5110 LCD will be used to display the data.
  • Digital buttons will be used to navigate forward and backward through screens
  • A potentiometer will be used to vary the menu option that is selected.
  • A reading will be taken every second – with an average taken every 10 seconds.
  • The display will show a bar which fills in as the distance/temperature increases.
  • The visual alert will be a red/green/yellow LEDs (solid colour) and when the distance/temperature is very low/high (respectively) all LEDs flash together (2 Hz).
  • A 2 kHz tone will be generated by driving the piezo with a PWM waveform.
System Architecture Block Diagram:
User Interaction
PCB Design:
  • Keep inputs and outputs around the edges of the PCB – easier user interaction.
  • Put the Screen in the middle of the PCB and make it unobstructed
  • Include sensors at the edges of PCB (especially SRF02).
  • The distance sensor needs to be above the screen and facing out so the user can hold it in front of them to measure a distance.
  • B1 and B2 are simple buttons to navigate backward and forward (respectively) between the menu screens.
  • The pot is located at the bottom of the board in its own space so it can be adjusted.
  • The switching regulator will be underneath the screen.
  • The switch, SW and LED1 are power-related components. The switch is used to control the power and the LED is an indicator to show it is on.
  • LEDs: LEDR, LEDY and LEDG are used as visual indicators.
  • The reason the vertical edges of the PCB are kept fairly clear is because the mbed has to be soldered on the underside as well as a battery pack.
  • NB: The whole PCB will be handheld in a portrait orientation however it was rotated into a landscape position to save space.
Presentation on Display:
  • A series of menus will be used.
  • Due to screen size limitations, the maximum number of options per menu will be two if the screen is to appear aesthetically pleasing.
  • This means that 3 menus are needed:
    • 1st = Sensors or Options
    • 2nd = Distance or Temperature (Sensors)
    • 3rd = Various Options (i.e. Toggling Sound/LEDs)
  • Each menu besides the options menu will have a title.
  • Depending on how crowded the page is, a border may be added around the page.
  • Welcome Screen:
  • Initial Menu:
  • Sensor and Options Menu:
  • Distance and Temperature Screens
  • The diagram below describes the navigation through the menu screens starting from the top left.
  • The square at the side of each option appear when the specific option is selected and each arrow corresponds to the next screen that is displayed.
  • When the back button is pressed, the sequence moves back to the previous screen.
    DAB over 10 years ago
    Very good design description.
    The more detail you can plan with, the easier it is to test and integrate.
    Well done.
  • clem57
    clem57 over 10 years ago
    A nice plan. Keep up the good work.
    Clem
