Legacy Personal Blogs Failure and things I need to work on
  • Author Author: ajkatz83
  • Date Created: 5 Apr 2018 7:46 PM Date Created
  • Views 842 views
ajkatz83
ajkatz83
5 Apr 2018
Unfortunately for me, I ran out of time with the Hack Like Heck contest. For most people it would be like any other contest, but for myself, I was really looking forward to accomplishing something big for here, personally speaking, that for once I wasn't as "crazy" and I thought for the so-called engineering that I am doing in the spare time I have. With regards to the contest, I should have been really focused in March to getting that design working and dimensioned properly. For most of March I had been bounce from one trade show to the next across great distances and such ,and let alone time in Coast Guard wise, which took away from what I wanted to do. I simply figured that on the downtime that I was home I could bust out all the electronics, design this enclosure with no problems, and before I knew it be back n the road again knowing I was one step closer to wrapping this all up. Unfortunately that is not what transpired at all; by the time I came home from Orlando one week was less than a few days I had to be out in Dunkirk for the next, and very little got done though I was certain what I was doing was enough, and surely it wasn't.
As optimistic as I was knowing that at least I was doing something, another issue crept up that I just couldn't known but should have. While I was doing well using the calipers and taking dimensions for every board and switch, I came to find out yesterday that the design was thrown off by virtue that the top piece for the screen was too big! What I didn't do was take the measurements for the LCD itself and just not the glass polarizer.  SO basically there was two measurements involved and because of that the design after the fact was thrown off and the gaming portable was scrapped. I really tried so hard to to be as accurate as I could in thinking I knew what I was doing with those calipers, and in the end everything was messed up. I wanted my first design that I did myself good so much better than that rather than a failure like everything else. I understand it was just a contest, I just figured I would have done better for myself than what I eventually found out to be a disaster. I have been so immersed in electronics but not so much when it comes to design. Going through the school of hard knocks to then figuring it all out on your own makes me wish I had been in some shop class rather then photography in high school--at least it would have been useful later on.
Anyways, let alone the screen, a lot of the other boards (boost converter, Class D stereo amp ) all have a tight fit to them, let alone the micro USB port is totally blocked.
I forgot to even make a provision for the 6000mAh battery to fit in as well.
Above all, transferring dimensions from the caliper to Fusion 360, not sure how to correct that when it seemed everything was going right. I guess that'll be something to look up on Udemy or Lynda.com I imagine.
  • gam3t3ch
    gam3t3ch over 8 years ago +3
    Aron, I would still hope you finish up the project and show us I would like to see personally as well. As a self taught guy myself I know the frustration all too well. Even on my project for it I messed…
  • ajkatz83
    ajkatz83 over 8 years ago +2
    I am glad you understand. I couldn't believe it after more than a day of printing and more than month of design between two designs, it just came to the end, yesterday to find out all these dimensions…
    jw0752 over 8 years ago +1
    Hi Aron, Thank you for taking the time to share your story. So often we see success written up here and it all looks so easy. Making things is hard and more often than not one or more failures lie in front…
  • gam3t3ch
    Aron,  I would still hope you finish up the project and show us I would like to see personally as well.  As a self taught guy myself I know the frustration all too well.  Even on my project for it I messed up with my dimensions not taking small details into consideration.  Will visit those again in the future tho.
    What I will say is the contest I did it for the shirt.. Sure the other stuff would be cool but really I just did it for me and had the time.  I have had lots of challenges on here I have missed out on in the past that would have been amazing to take part in.
    But there is hope put your stuff together and remember can always apply for the Content Partner Program
    Best of luck and let us know when you get that all done!
    Keep on making!
  • gam3t3ch
    Keep on making!
