Legacy Personal Blogs First Arduino Project
  • Author Author: jeepingoody
  • Date Created: 29 Mar 2017 2:35 AM Date Created
  • Views 980 views
  • lcd
  • humidity sensor
  • temperature display
  • dht11
jeepingoody
jeepingoody
29 Mar 2017
Completed my first project with the Arduino.
Display the temp and humidity from a DHT11 sensor on an LCD
Took me all day but finally got it done. Code is as follows
// display temp and humidity on LCD
#include <SimpleDHT.h>
#include<LiquidCrystal.h>
LiquidCrystal lcd (4,5,6,7,8,9); //pins for RS, E, DB4, DB5, DB6, DB7
// for DHT11,
//      VCC: 5V or 3V
//      GND: GND
//      DATA: 2
int sensor = 10; // sensor is on pin 10
SimpleDHT11 dht11;
#define LED 11  // LED is on pin 11
void setup() {
// LCD setup
  lcd.begin(16,2);
  lcd.clear();
  pinMode(LED,OUTPUT); // set led to output
void loop()
  lcd.clear(); // clear LCD
  // Sensor Check.
  byte temperature = 0;
  byte humidity = 0;
  if (dht11.read(sensor, &temperature, &humidity, NULL)){
  // if sensor shows no data let me know
  lcd.setCursor(1,0);
  lcd.print("**************");
  lcd.setCursor(0,1);
  lcd.print("**CHECK SENSOR**.");
  delay(1000);
  digitalWrite(LED,HIGH); // turn on LED if no data found
  return;
 // convert c to f
float c = 0;
  float temp = 0;
  c = temperature;
  temp = (1.8 * c) + 32;
 // Display data
  digitalWrite(LED,LOW);   // turn LED off
  lcd.clear();
// Display Temp
  lcd.setCursor(0,0);
  lcd.print("TEMP ");
  lcd.print(temp,1);
  lcd.print(" F");
  delay(5000);
// Display Humidity
  lcd.clear();
  lcd.setCursor(0,1);
  lcd.print("Humidity ");
  lcd.print((int)humidity);
  lcd.print("%");
  delay(5000);
  • gihu
    gihu over 9 years ago
    Hi Matt,
    First post? Really nice, maybe a video with everything working could have completed it.
    Nice work!!
  • jeepingoody
    jeepingoody over 9 years ago in reply to gihu
    Yes first post as well. I'll try a video on step two
  • jeepingoody
