Legacy Personal Blogs FPGAs and Xilinx
  • Author Author: ajkatz83
  • Date Created: 17 Feb 2018 10:51 PM Date Created
  • Views 829 views
  • logic
  • mos
  • commodore
  • pla
  • xilinx
  • commodore_64
  • socs
  • fpga dev
  • pld
FPGAs and Xilinx
ajkatz83
ajkatz83
17 Feb 2018
Taking that FPGA intro that was under the learning essentials has really got me curious now. During my introduction to this 8-bit re-innovation and revolution make new ways to work with 8-bit machines, so far with the Commodore SX-64 I have here, I have two replacement chips that are of a modern vintage inside.
One was a replacement for the PLA, which was known to get hot and burn out, ever so common. Now I find a simply Xilinx chip has been programmed and handling the device timing.
The Second, just recently, was the SID (Sound Interface Device) or MOS6581, which heats up very nicely too, and was scorching when I pulled just this evening because my diagnostic cartridge said it was bad and plus the nails in the coffin for it was simply no audio out. Again, a PLD type device was made up for the MOS6581 called a SwinSID I believe which gets close to the audio out of the original though there is no paddle control if this route is implemented. I didn't care to much seeing I never had paddle games anyways.
Third, this has been rather inspiring for my studies at Cleveland Institute of Electronics seeing I am on digital electronics course presently, and all this supplemental information I have gotten here has been beneficial from element14, though now stepping head 36 years later, what sort of FPGA dev board would be fun to experiment with? The SoC got my attention a bit seeing it looks like embedded applications would be easier an Arduino might not always be needed. SO simply, what do you think would be good to play with for an electronics student?
  • gecoz
    gecoz over 8 years ago +5
    Hi Aron, you can find many useful posts about FPGAs here on Element14 you can start from to get an idea on what could be more suitable for you. Try having a look at Not-as-expensive FPGA Boards for example…
    genebren over 8 years ago +1
    I have been involved in several instances where a chip that a company had engineered into a product went obsolete. Given this problem there are a couple of solutions: 1) re-design the product, removing…
  • gecoz
    Hi Aron,
    Try having a look at Not-as-expensive FPGA Boards for example, which contains many useful suggestions for boards you can start experimenting with.
    Also, you can check the FPGA Group for many more interesting articles on the subject.
    I hope this helps.
    Fabio.
    • Vote Up +5 Vote Down
  • gecoz
    Hi Aron,
    I hope this helps.
    Fabio.
