Legacy Personal Blogs G5A-234P relay - alternative: C-BT53 relay module
  • Date Created: 17 May 2012 9:54 AM Date Created
  • Views 814 views
  • g5a_relay
  • bt53
  • g5a-234p
  • relay
e14 Contributor
e14 Contributor
17 May 2012
The Cephos C-BT53 relay module is the ideal alternative for the obsolete Omron G5A-234P pcb small signal relay - with an identical footprint, this replacement component is the perfect solution to the ongoing problem with sourcing the BT53 type relays which are no longer available.
Further details and specification can be found at
http://www.cephos.com/BT53.htm
