Legacy Personal Blogs Getting Started with an Old Raspberry Pi #1 : Its a Model B (not a B+)
  • Author Author: dubbie
  • Date Created: 18 Feb 2019 12:35 PM Date Created
  • Views 5860 views
  • Comments 17 comments
  • raspberrry pi
dubbie
dubbie
18 Feb 2019
As I am thinking of taking part in the Picasso Design Challenge that uses a Raspberry Pi 3 B+ and not knowing very much about any Raspberry Pi I thought I would borrow one and see what I could do. I obtained an old one from my son which I am now attempting to get going.
I have searched some of the Element14 older material and managed to find out that I have a Raspberry Pi Model B (but not a B+). But so far I have not been able to find out how to connect it up so that I can at least turn it on and see what happens.  I think I need an HDMI cable but what else? Can anyone point me in the right direction for this very old Pi which is way past its Best Before Date?
Dubbie
  • ralphjy
    ralphjy over 7 years ago +6
    I would hate to discourage you, but if I were just starting out - I would just buy a new RPi 3B+ as a kit with power supply, pre-loaded SD card and case. I think you'll find that the old model RPi will…
  • luislabmo
    luislabmo over 7 years ago +5
    Hi dubbie , The minimum necessary to use a Raspberry Pi: First identify which RPi you have , this way is going to be less painful to deal with issues and also the GPIO mapping may be different, so this…
    beacon_dave over 7 years ago +5
    Perhaps have a read through these MagPi official guides to get a basic overview of the R-Pi: https://www.raspberrypi.org/magpi-issues/QuickStart_v1.pdf https://www.raspberrypi.org/magpi-issues/Beginners_Guide_v1…
    https://www.raspberrypi.org/magpi-issues/Beginners_Guide_v1.pdf
    https://www.raspberrypi.org/magpi-issues/Beginners_Book_v1.pdf
    Also take a look at the on-line help:
    https://www.raspberrypi.org/help/
    Just keep in mind that you are on an older model of the Pi, so there will be some differences encountered.
    • Vote Up +5 Vote Down
    dubbie over 7 years ago in reply to beacon_dave
    Dave,
    Thanks for this information. I looked up some of these links which are very helpful. Although mostly aimed at the 3B+ or 2B they are general enough to be helpful to me. I am rapidly coming to the conclusion  that the Pi might not be for me unless I can get hold of a HDMI connectable display and a USB keyboard. Still, I've learnt some stuff about Pis.
    Dubbie
    beacon_dave over 7 years ago in reply to dubbie
    If you want familiarity with the Raspbian software, then there is also 'Raspberry Pi Desktop' available which you can run on a PC or Mac computer.
    https://projects.raspberrypi.org/en/projects/install-raspberry-pi-desktop
    https://www.raspberrypi.org/downloads/raspberry-pi-desktop/
    You can install it on an unused laptop as the native OS, or run it as a live disc or virtual machine.
    Dave,
    This is really helpful. I have a couple of old laptops that I was thinking I might just scrap but if they could have a second life that would be great. I'm not entirely sure I fully understand what the Raspberry Pi Desktop is but I think it is some sort of emulation of a Raspberry Pi that runs Raspberry Pi programmes - but doesn't have the Raspberry Pi I/O capability. It isn't clear to me yet whether these programmes can then be downloaded to a Raspberry Pi or not. I might be confusing the programme with the executable here.
    Also, I wasn't sure if you can make a USB stick with Raspberry Pi Desktop on which can be run from any Windows PC (without affecting the Windows PC in any way?). The YouTube video I watched mentioned something about persistence but I wasn't sure what that was.
    I also saw that you do seem to be able to connect a Raspberry Pi Zero directly to the Raspberry Pi Desktop and then create and run programmes on the zero that were created using the Desktop. This sounds like a great idea to me.
    Now I have a second aspect of Raspberry Pi to look into - the other was accessing my old Raspberry Pi 1B via Ethernet. This all sounds like great fun.
    I can remember when Windows first came out when you could access hardware directly from within your C programmes. My students did some great projects controlling hardware from PCs. Then Windows introduced the Hardware Abstraction Layer and that was the end of that. A backward step for me in programming but I guess a necessary step for Windows to increase security.
    Dubbie
    Raspberry Pi Desktop should be ideal for giving those old laptops a new lease of life.
    More info on desktop in MagPi issue 53 page 70:
    https://www.raspberrypi.org/magpi-issues/MagPi53.pdf#page=70
    Yes you can boot and run from DVD or USB and leave the existing OS untouched. By default with a live disc any changes don't get saved locally. You can however enable 'persistence' and that allows you to save changes to a USB drive.
    You may also be interested in this web-based Sense Hat emulator:
    https://trinket.io/sense-hat
    The off-line version of the emulator is included in later versions of Raspbian as well.
    Dave,
    Another set of exciting things to be investigated without too much difficulty. It seems like thee is no end to what Raspberry Pi or simulations/alternative implementations can do. I'll have to try and stick to the initial simpler things or I'll just get carried away looking at stuff and never do anything.
    Thanks foro all this good information.
    Dubbie
