Legacy Personal Blogs Getting started with PiFace
  • Date Created: 27 Dec 2013 4:46 PM Date Created
  • Views 747 views
  • getting
  • started
  • piface
e14 Contributor
e14 Contributor
27 Dec 2013
I used to play with a Lego train set with BBC Basic on the BBC microcomputer 30 years ago and thought that I'd now like to do the same with the Raspberry Pi and the PiFace Digital interface. However, it all seems far more complicated than BBC Basic! I  connected everything up and followed the instructions in the PiFace Digital Guide. I typed:
sudo nano etc/modprobe.d/raspi.blacklist.conf
and was presented with some sort of text editor, where I was told to add a # to the line blacklist/spi2708. However, there was no text there at all so I couldn't do this.
Instead I tried the alternative of loading the SPI driver by hand. The commands sud modprobe spi-bcm2708 seemed to load a succession of data and I proceeded as far as the sudo reboot instruction as requested. Thereafter I tried to start the PiFace emulator with the request  piface/scripts/piface-emulator, but was told that this didn't exist.
Assuming that I therefore did not have the PuiFace software installed I tried the instructions in the "install.txt" file (with sudo apt-get install .... etc.) but was told that this couldn't be done.
So! Can anyone one tell me what I need to do to get started?
Having failed, after another hour of trying, I decided to try Python instead. I followed the instructions on page 153 and 154 of theUser Guide  tofor  writing the  HelloWorld progarm, but, when I click on the RUN NOW option, or press F5, I get the message "Invalid Syntax". I've checked and double-checked, but I have written it EXACTLY AS IN THE BOOK.
What am I doing wrong?
  • videogame95
    videogame95 over 12 years ago
    go on to your terminal widow
    go into sudo raspi conf
    enable spi
    sudo apt-get update
    y
    sudo apt-get install upgrade
    yes or what ever comes up ?
    sudo reboot
    type in terminal window  sudo apt-get install python3-pifacedigital-emulator
    when load type y
    sudo reboot
    Then do the piface emulator will be on you desktop and will work I v'e  just done this again today and it work well
    kick on link below this will give you a lots of up to date code programmes etc.
    how to install piface etc.
    hope this works for you
    James Harris
    PiFace – PiFace Digital
  • videogame95
    enable spi
    sudo apt-get update
    y
    sudo reboot
    when load type y
    sudo reboot
    James Harris
