Legacy Personal Blogs Getting started with Raspberry Pi
  • Author Author: bhavikbhansali
  • Date Created: 20 Apr 2015 4:25 PM Date Created
  • Views 778 views
  • raspberry_pi_setup
  • getting_started_with_raspberrypi
bhavikbhansali
bhavikbhansali
20 Apr 2015
raspbian
How to Install Raspbian on SD card ? here some easy step for installation of OS. BUT before installation some information is required on Raspberry pi.
Raspberry pi is a credit card size computer. And we know that every computer want an Operating System to run that particular  hardware. Here I am showing that how to install Raspbian OS to micro SD card.
raspberrypi B+ ports name
I want to give some information about Raspbian and Raspberry pi.In Raspberry pi we install OS on memory card (micro SD) and i recommended to use Class 10 micro SD 16 GB card which read and wright speed is higher then normal micro SD card (class 4). In Raspberry pi OS is boot only from SD card rather than other USB devices. Now you are excited to know that How to Install Raspbian on SD card ? and answer is given below.
How to install Raspbian on SD card. Here  some  steps for OS installation on micro SD (class 10 micro SD)
  • First step is too much easy just you have to show some passion. First you have to install two software which is Raspbian OS and win32DiskImager to your computer. NOTE : ( 1.) computer have card reader port because with this port we wright OS to memory card. ( 2.)Click on raspbian OS and win32diskimager to download both software. ( 3.) download zip file of Raspbian OS.
  • Now extract Zip folder of Raspbian OS and install Win2DiskImager.
  • Insert micro SD card with adapter to computer. NOTE : cad is fully blank
  • Open Win32DiskImager as Run as administrator.
  • First select Raspbian extracted folder and select write.
  • One more time need some passion. hurrah OS is loaded into micro SD card.
  • Put micro SD card to Raspberry pi card slot connect USB mouse and key board.
  • Connect screen with HDMI cable.
  • Connect power cable (mini USB) and switch on the switch.
  • One window is appear in this window select 3rd option and in that option select graphical inter-phase option.
raspbian boot window
  • Last time need some time to start OS. It is load some information. After this OS is install to SD card.
  • Hurrah raspberry pi is ready to use. Raspbian install successfully on your SD card.
raspbian home screen 2
Home screen of Raspbian OS.
( NOTE : IF ask for username and password then insert pi as username ans raspberry as password in raspbian password is not came with ***  or any other symbol it is invisible so just type raspberry and press enter. )
Hope that you learn that how to install Raspbian on SD card with much easier way.
