Legacy Personal Blogs HDC1000EVM Python code for Raspberry Pi
  • Author Author: wymand
  • Date Created: 16 Apr 2015 12:08 AM Date Created
  • Views 1157 views
  • python
  • hdc1000evm
  • raspberry-pi
wymand
wymand
16 Apr 2015
Here is a sample program that starts a stream from the HDC1000EVM, reads 100 returns and  stops the stream:
import serial
#sample program to read Texas Instruments HDC1000EVM
#initialization and open the port
#possible timeout values:
#    1. None: wait forever, block call
#    2. 0: non-blocking mode, return immediately
#    3. x, x is bigger than 0, float allowed, timeout block call
ser = serial.Serial()
#ser.port = "/dev/ttyUSB0"
#ser.port = "COM4:"
#ser.port = "/dev/ttyACM1"
ser.port = "/dev/serial/by-path/platform-bcm2708_usb-usb-0:1.2:1.0"
ser.baudrate = 115200
ser.bytesize = serial.EIGHTBITS #number of bits per bytes
ser.parity = serial.PARITY_NONE #set parity check: no parity
ser.stopbits = serial.STOPBITS_ONE #number of stop bits
#ser.timeout = None          #block read
#ser.timeout = 1           #non-block read
ser.timeout = 2              #timeout block read
ser.xonxoff = False     #disable software flow control
ser.rtscts = False     #disable hardware (RTS/CTS) flow control
ser.dsrdtr = False       #disable hardware (DSR/DTR) flow control
ser.writeTimeout = 2     #timeout for write
try:
    ser.open()
except Exception as e:
    print ("error open serial port: " + str(e))
    exit()
if ser.isOpen():
    try:
        ser.flushInput() #flush input buffer, discarding all its contents
        ser.flushOutput()#flush output buffer, aborting current output
                        #and discard all that is in buffer
        #write data
        #ser.write(bytes(43))
        ser.write(serial.to_bytes([0x33]))
        numOfLines = 0
        while True:
            response = ser.readline()
            if (str(response).find(",") == -1):
                print("start data: " + str(response))
            else:
                print("      Temperature: " + str(("{0:.2f}".format(((float(int((str(response).split(',')[0]),16))/float(65536)) * 165) -40)))+ u"\u00B0" + "C")
                print("      Temperature: " + str(("{0:.2f}".format((((((float(int((str(response).split(',')[0]),16))/float(65536)) * 165) -40) * 9) / 5) + 32)))+ u"\u00B0" + "F")
                print("Relative Humidity: " + str(("{0:.2f}".format((float(int((str(response).split(',')[1]),16))/float(65536)) * 100)))+ "%")
            numOfLines = numOfLines + 1
            if (numOfLines >= 100):
                #ser.write(bytes(44))
                ser.write(bytes(52))
                print("read data: " + str(response))
                break
                ser.close()
    except Exception as e1:
        print ("error " + str(e1))
    ser.write(serial.to_bytes([0x34]))
    print("last data: " + str(response))
    ser.close()
else:
    print ("cannot open serial port ")
  • dbwilliams
    dbwilliams over 11 years ago
    Thanks, I guess I'll have to try it out on the Pi too!
  • dbwilliams
