Legacy Personal Blogs HDI Rigid-flex PCB High frequency Thick copper Multilayers PCB One stop shop
  • Date Created: 31 Mar 2015 2:01 AM Date Created
  • Views 583 views
e14 Contributor
e14 Contributor
31 Mar 2015
Factory Capacity of FPC
Tapes of FPC:   single-sided,single-sided hollow-out board,double- sided,double-sided  boards, 3~6 layered board,Rigid-Flex PCB
substrate copper thickness of FPC:     8um  12um 17.5um、35um  70um
Min line width/space:                  2mil/2mil
Min width/space:                       4mil(0.10mm)
Min mechanical drilling hole diameter: 500mm X600mm
Surface Finishing:  ENIG,Immersion Tin,Immersion Sliver,OSP,Gold Finger Plating,Tin Plating,Whole Panel Plating
Color of Solder Mask:  White,Black,Yellow,Red,Green
HDI Capacity
Tapes of HDI:              1+N+1 HDI,2+N+2 HDI,3+N+3 HDI,Arbitrary
Min mechanical drilling hole diameter:   8mil(0.20mm)
Min liser drill diameter:                3mil(0.075mm)
Blind hole's Aspect Ratio:               1:1
Surface Finishing:
Color fo solder Mask:   White,Black,Yellow,Red ,Green
High-Multilayers Capacity
Layer Count:   36
Meterials:   Hologen-free materials ,PI Materials,BT materials,ppo,mixed compression,high frequency (Roger、 Arlon\Taconic、Nelco、 Taining,Microwave F4B,Isola...)
Min drilling hole diameter:8mil(0.20mm)
Max Aspect Ratio:   16:1
Max finished boare size:   23″* 32″(584mm*812mm)
Surface Finishing: Lead HASL,Immersion Gold,Immersion Tin,Immersion Sliver,whole panel plating, OSP,HASL,Hard Gold plated,Gold Finger,and mixed surface treatmeat.
Color of Solder  Mask: White,Black,Yellow,Red,Green,Matt
Special Technology:   High-frequencry mixed compression,back drilling,Press fit hole,metal substrates,buried capacitance technology and buried resistance technology
[url=http://www.huanyupcb.com]HDI PCB Manufacturer[/url][url=http://www.huanyupcb.com]PCB Fabrication[/url]
[url=http://www.huanyupcb.com]pcb prototype [/url] [url=http://www.huanyupcb.com]Express PCB[/url]
[url=http://www.huanyupcb.com]Rigid-flex PCB Supplier[/url]
[url=http://www.huanyupcb.com] Flex PCB [/url] [url=http://www.huanyupcb.com] Aluminium pcb [/url]
