Legacy Personal Blogs Help- Special effect Led Christmas light controller
  • Date Created: 19 Feb 2014 5:12 AM Date Created
  • Views 455 views
  • led
  • christmas
e14 Contributor
e14 Contributor
19 Feb 2014
I am posting here hoping to get idea and help with my project that i wanted to make for an long time.
Here the specifics i wanted an 64 channels of led with red, yellow, blue, and white.  There will be 16 clusters of four colors, into one chip that will be bright enough to imimmuliate an white 6" globe .  I want to have an ability to control all 64 led total with full spectrum of colors combinations , seperated by timing including even infinity as long program runs, wide range of gradual to fast transition, some effects like flickering preprogrammed , brightness intensity for each led, by GUI program created for this.   The programming should last a good 90 minutes, with loop capability, and pause/play when needed.  Possible with audio recognition matching effects.
Possible using cat6 with ethernet connection to easily take apart and set for another performance, from main controller and to light chip, same distance for all.  this will be indoor project for an christmas play i always dream of.
operating using one of raspberry os, and program designed for this, along with relay channel card, aruindo, and whatever it will takes to make it work.
