Legacy Personal Blogs Help with high volt transistor
  • Date Created: 25 Feb 2015 7:25 PM Date Created
  • Views 1220 views
  • Comments 7 comments
  • amplifiers
  • transistors
  • electronics
  • power
  • solid_state
e14 Contributor
e14 Contributor
25 Feb 2015
Hello,
I am trying to find a transistor or amplifier that can work with large voltages, like 100 kilovolts. I am trying to build an x-ray machine and need the transistor to vary the voltages with an Arduino. The transistor will separate the Arduino from the high voltages.
Is there a place I could find that kind of transistor or amplifier? Ideas or options that are alternative approach to my problem are welcome.
    jw0752 over 11 years ago +1
    Hi Eddy, There are 2 things to control with respect to x-ray tubes. The high voltage will control the energy of the x-rays that are produced. Higher voltage produces a shorter wave length higher energy…
    Hi Eddy, There are 2 things to control with respect to x-ray tubes. The high voltage will control the energy of the x-rays that are produced. Higher voltage produces a shorter wave length higher energy x-ray. The current to the x-ray tube's filament will control the mA of the x-ray tube and density (brightness) of the x-ray beam. All of the commercial x-rays I have ever seen control the kVp with a variac or other control of the lower voltage that generates the high voltage. The mA control is always on the current that heats the x-ray tube's heater for the cathode. More heat = more free electrons.
    Note: This type of project can be dangerous electrically and also from exposure to harmful radiation. If you need x-rays for a real reason it might be better to use an old x-ray head that has the proper shielding and collimation. Statistically exposure to x-rays increases your chance of developing cancer.
    e14 Contributor over 11 years ago in reply to jw0752
    Thanks for your input. Is of great help.
