Legacy Personal Blogs Hercules LaunchPad and GaN FETs - Side Note B: Look at the PCB
  • Date Created: 6 Dec 2016 8:12 PM Date Created
  • Views 6654 views
  • Comments 29 comments
  • kicad
  • seeed
  • pcb_layout
  • texas_instruments
  • gan
6 Dec 2016
I'm designing a BoosterPack to evaluate GaN devices with the help of a microcontroller.
I've received PCBs from Seeed. Let's have a look ...
This is my first Seeed order (a kind element14 community member gave me a rebate coupon that I happily used).
Board specifications:
  • PCB Dimension - 10cm Max*10cm Max
  • Layer - 4
  • PCB Thickness - 1.6mm
  • PCB Qty. - 5
  • PCB Color - Green
  • Surface Finish - ENIG
  • Copper Weight - 1oz.
  • Panelized PCBs - 1
  • Expedited Option - NO
The price without shipment for this board is 65.12€. Shipping was 7.37€. The coupon got me 9.15€ off ($ 10). Totals to 63.97€
This design requires 2oZ copper layers. My budget can't carry the cost of such a board - so I will not be able to draw full current out of my design.
This is a compromise, one of the many I had to make. I tried to avoid compromises in the design, but did make them when ordering.
Getting a board that has enough copper on it will not require a design change. It's just ticking a different option when ordering and coughing up the monies.
I'd rather do that after I validated that I didn't make mistakes in the PCB layout.
Just like previous designs I did with OSHPark, the Seeed boards look very good at first inspection.
This design is 4 layers, so I have no mechanism to look at the two inner layers. The top and bottom layer look very nice, so that's a good sign.
In the images below, the artist renditions on the left side are generated by the Seeed portal.
The photos on the right side are the actual thing. Click on them to get a detailed view.
Populate Order
This is the first time I'll populate a two-sided board. I'll use hot air for the smd components.This is how I plan to approach it:
  1. solder the GaN IC and the inductor. These two have the pins under the device. I'll have to massively bombard them with heat to transfer the energy underneath where the solder paste is.
    I'll use the pre-heater that shabaz gave  me to get the whole board to a close-to-reflow temperature.
  2. then all the smd components on the bottom side. If they fll of later, that's not a big deal, because the are only few.
    I'll also use the pre-heater but on lower temperature, because its heat will be radiating on the inductor and GaN chip.
  3. Then I'll do the remaining top smd components.
    The pre-heater again on a temperature low enough to not desolder the bottom components.
  4. the trough-hole components by hand
It is my first time. I'd be happy to take your advice on the preferred order to solder the components.
The tools I have at hand:
  • hot air
  • soldering iron
  • pre-heater
edit: I've attached the waveform of one High input pulse as hi01.wfm.
If you have a Rigol DS1052E you can upload that to your scope and examine the ringing with cursors.
Related Blogs
Hercules LaunchPad and GaN FETs - Part 1: Control Big Power with a Flimsy Mouse Scroll Wheel
Hercules LaunchPad and GaN FETs - Part 2: Make a BoosterPack
Hercules LaunchPad and GaN FETs - Part 3a: BoosterPack Layout - Reference Design
Hercules LaunchPad and GaN FETs - Part 3b: BoosterPack Layout - my version
Hercules LaunchPad and GaN FETs - Side Note A: BoosterPack Layout - Custom KiCad Parts
Rotary Encoders - Part 1: Electronics
Checking Out GaN Half-Bridge Power Stage: Texas Instruments LMG5200 - Part 1: Preview
Rotary Encoders - Part 4: Capturing Input on a Texas Instruments Hercules LaunchPad with eQEP
Vintage Turntable repair: Can I fix a Perpetuum Ebner from 1958 - part 4 - Hercules LaunchPad Enhanced PWM try-out
hi01.zip
  • michaelkellett
    michaelkellett over 9 years ago in reply to Jan Cumps +2
    Hello Jan, I do similar parts by placing the board directly onto a hotplate. I never feel sure just how hot I'm getting things if I use a hot air blower. I do use leaded solder for the lower melting point…
    Jan Cumps over 9 years ago +1
    The two difficult components are soldered. I've measured for solder bridges, all OK...
  • michaelkellett
    michaelkellett over 9 years ago in reply to Jan Cumps +1
    I use hotplate for four and two layer boards - not had a board problem yet. It's a cheap Chinese hotplate but the temperature regulation isn't bad. MK
  • michaelkellett
    Hello Jan,
    I do similar parts by placing the board directly onto a hotplate. I never feel sure just how hot I'm getting things if I use a hot air blower. I do use leaded solder for the lower melting point (and better wetting).
    I solder the Rs, Cs, SOICs and TSOPs with a soldering iron.image
    This is a test board for the LTC3780 buck boost controller - very efficient but also noisy, like all other boards I've seen with this chip, including the LT demo board.
    (Same inductor as you chose !)
    MK
  • michaelkellett
    Hello Jan,
    MK
    Jan Cumps over 9 years ago in reply to michaelkellett
    Does the hotplate technique work with a four-layer board? I use a pre-heater (hot-air blower on the underside) but haven't risked yet to use that as a reflow device.
  • michaelkellett
    MK
    Things learned until now:
    • one wrong footprint selected for a capacitor
    • wrong footprint created for the power connectors
    • inductor too close to GaN chip. The inductor doesn't nicely pull itself into place when reflowing and I've placed the IC as close as I could next to it. No good. (I also see that the inductor twisted itself a little on michaelkellett's pcb).
    • 0402 and 0603 don't work well when selecting hand soldering footprint and then soldering them with hot air. I selected these to train myself, but it's a challenge for home rework with mediocre tools.
    • more care needed when reflowing tiny LEDs. I've damaged two.
    I expect a working project though. None of the things I've encountered (until now) are showstoppers...
    Jan Cumps over 9 years ago in reply to Jan Cumps
    Firmware to the rescue when you've swapped two rotary encoder pins
    I've fixed the board layout for C30, P2 and P3. New archives are attached to the relevant posts.
    C30 was me selecting a wrong existing footprint.
    P2 and P3 is pure blindness and lack of feeling for numbers.
    In the KiCAD footprint editor, I had put the (0.0) in the middle of the connector.
    I should have then placed pin 1 on X coordinate -(distance between pins)/2. Pin 2 on X coordinate +(distance between pins)/2.
    Silly me first halved the distance, and then applied above formulas.
    Doh.
