Legacy Personal Blogs HIROSE FH52 SERIES|0.5mm / 1mm Pitch, 2mm Height, FFC/FPC/ ZIF Connector
  • Author Author: t.adegoke
  • Date Created: 16 Oct 2020 8:24 AM Date Created
  • Views 746 views
  • zif
  • connector
  • high temperature
  • 1mm_pitch
  • pull force
  • robust
  • hirose
  • ffc/fpc_connector
  • 0.5mm_pitch
  • fh52
t.adegoke
t.adegoke
16 Oct 2020
HIROSE Electric Co. Ltd, a world-class manufacturer in connectors, is pleased to introduce our FH52 series.
These series are high-reliable connectors with a robust structure designed to ensure that the actuator cannot be removed even under rough operating conditions.
In addition, the metal fittings provide additional support to the actuator from underneath.
As a result of these features, the connector can withstand a high pull force of 30N in the horizontal direction when using a ten-position tabbed FPC with a thickness of 0.3mm; achieving high operating temperatures of up to -40°C - +105°C.
CLICK THE LINK BELOW
https://uk.farnell.com/search?st=hirose%20FH52
