Legacy Personal Blogs how can i adjust the PW-0268 ultrasonic sonar ranging IC frequency system ?
  • Author Author: bouazzaouisamir
  • Date Created: 3 Mar 2017 6:18 PM Date Created
  • Views 1415 views
  • Comments 6 comments
bouazzaouisamir
bouazzaouisamir
3 Mar 2017
hello everyone;
i'm working now the PW-0268 ultrasonic sonar ranging IC and i want to augment the range of detection by changing the value of the R4 and C2 so that i can work with a frequency system equal to 60 Khz but i don't know how i can do that so can someone help me and explain how i can adjust the frequency?
N.B : in the data sheet the said it can reach the 18 meters
sorry for my english.
    dougw over 9 years ago +1
    The frequency looks like it is inversely proportional to the capacitance. To decrease the frequency by a factor of 10, try increasing the capacitance by a factor of 10 to 220pf.
  • michaelkellett
    michaelkellett over 9 years ago +1
    Why do you think that increasing the frequency will increase the range ? On the data sheet it asks you to contact the chip manufacturer for an 18m capable design which suggests that the standard circuit…
  • bouazzaouisamir
    bouazzaouisamir over 9 years ago in reply to dougw +1
    i will try it tanks douglas.
  • michaelkellett
    On the data sheet it asks you to contact the chip manufacturer for an 18m capable design which suggests that the standard circuit won't do.
    What range are you achieving now and what transducer(s) are you using ?
    MK
  • bouazzaouisamir
    bouazzaouisamir over 9 years ago in reply to michaelkellett
    thanks michaelkellett;
    if u read the data sheet u can find that all the parameter are depend on the frequncy clock system.
    however , i'm using the SRM400 is a sonar ranging module that use 400EP14D transducer and the max range is 150 cm.
  • bouazzaouisamir
    bouazzaouisamir over 9 years ago in reply to bouazzaouisamir
    and the max range we want to achieve is 10m
  • bouazzaouisamir
    dougw over 9 years ago in reply to bouazzaouisamir
    Some Maxbotix sensors can reach 10m - if you can afford them.
