Legacy Personal Blogs How Many Tools Does it Take To ....... Remove a screw from the wall
  • Author Author: dubbie
  • Date Created: 29 Aug 2020 12:11 PM Date Created
  • Views 3216 views
  • Comments 20 comments
  • tools
dubbie
dubbie
29 Aug 2020
I've always known that it takes many more tools than you think to do even the simplest of jobs and today I was able to confirm that. One of my bedrooms is being redecorated and this involved removing some box shelve units, which in itself was very straight forward, but it did leave the screws still fixed into the wall. I think the shelves were put up some 20 years ago so have had plenty of time to fuse into place. Additionally, they were also unusual screws as they were much longer than expected, being 5 cm long. Fortunately they were crosshead and I managed to remove 3 of the four using basically brute strength. How I put them in I cannot imagine - I must have been much stronger 20 years ago.
For the last screw every cross head screwdriver I used wasn't good enough and I ended up stripping the screw head. So, I used a junior hacksaw to cut a slot, then a standard hacksaw to make the slot wide enough for a flat blade screwdriver and eventually managed to remove the screw. The tools I used are shown below - and I used them all (except the hammer)! Plus a step ladder.
So from top to bottom:
1) Junior hacksaw.
2) Large pliers (a gift from Element14 - thanks very much) Tried to use these to rotate the screw - they didn't work.
3) Small pliers (for trying to remove the wall plug - didn't work)
4) Small wooden handles flat blade screwdriver (Not big enough)
5) Ratchet screwdriver flat blade (Not big enough)
6) Large wooden handled screwdriver flat blade (Finally did the job once a slot was cut into the screw head)
7) Rubber handled flat blade screwdriver (a gift from Element14 - thanks very much) Just not big enough.
8) Ratchet screwdriver cross head. (Worked for three of the screws just not for the last one)
9) Standard hacksaw.
10 Drill bits for drilling out the wall plug.
11) Set of screwdriver bits (Used with tool 8.)
12) Hammer (Actually I don't think I did use this)
13) Cordless drill (Used to remove the wall plug - mostly)
14) Step ladder (Not shown.)
So I had to use 13 tools (I haven't counted the hammer) to remove one screw from the wall, along with it's accompanying wall plug.
Below is the hole I ended up with. Parts of the wall plug are still inside this hole but I thought this hole is big enough as it is so I stopped.
I was surprised at how many tools I did need for this seemingly simple task.
Dubbie
    jw0752 over 6 years ago +5
    I like jobs like this they present a challenge. I also like to buy new and special tools so a tough job often gives me a pretext to add a new member to my arsenal of tools. I have often used a vise-grip…
  • Andrew J
    Andrew J over 6 years ago +5
    This would be a lot more believable if there was a can of WD-40 on the table
    beacon_dave over 6 years ago +5
    I don't see the 48" stilson pipe wrench or the hydraulic ram though ? Must be a small job...
  • kmikemoo
    kmikemoo over 6 years ago
    I think your count is really 17 because you're still missing the putty knife for the filler compound to fill the hole, the sandpaper and sponge to smooth the filler and the paint brush to hide it all.
    For me, it would have been vice grips early, rip off the head, pound it in with the hammer, wind up making a bigger hole and spend three days trying to hide it all with filler compound.
  • kmikemoo
    dubbie over 6 years ago in reply to kmikemoo
    Mike,
    I think it'll be a lot more than just an additional four tools. There is the filling, but then there is the local sanding down,, then using one of those long sanding jobbies, followed by a flat power sander, then undercoat, plus top coat (hopefully only one top coat). The most important tool now is ££££ which I will give to someone else to do it for me!
    Dubbie
    PS I have knocked in nails and screws and filled over, but the walls have a slight dampness and eventually the screws rust and make a mark. Then you have to create a massive hole to get the rusty screw out. I thought I'd avoid that post-painting process.
