Legacy Personal Blogs How to build a Cell Phone
  • Date Created: 4 Mar 2016 6:54 PM Date Created
  • Views 3204 views
  • Comments 10 comments
e14 Contributor
e14 Contributor
4 Mar 2016
I am having a problem with my project as I struggling to build a dialer or a DIY Cell Phone. The reason why I am trying to build my own dialer is because I am trying to continue with my project as cheap as possible. PLEASE HELP..............................................
  • clem57
    clem57 over 10 years ago +1
    Help? what have you built or designed so far? And what are your cost constraints. Just a note: building one cell phone is great as a learning process, but cannot be done less than a typical cell phone…
  • mconners
    mconners over 10 years ago in reply to mcb1 +1
    I think the gsm shields are tested and fcc compliant, you need to provide a sim card from a cellular company. As I said, it's a novelty. Mike
  • clem57
    Help? what have you built or designed so far? And what are your cost constraints. Just a note: building one cell phone is great as a learning process, but cannot be done less than a typical cell phone with all the features they offer. just a quick Google gives DIY Cellphone | DIY Devices which is nice but $200.
    From Make your own cellphone from scratch. :
    Part of my motivation for making the phone -- and helping others to do the same -- is the fact that while cellphones are ubiquitous in our society, most of us have little idea what they're made of or how they work. In fact, you can make a cellphone in much the same way you'd make anything else: find the right parts, figure out how to connect them together, and try to do it in a way that's attractive and robust. Because of the ubiquity of cellphones, there are companies making the components they're made of; with some digging, I was able to find versions of these parts that are possible to buy in small quantities and that are possible to assemble by hand. This wasn't necessarily easy, but it's a very different problem than trying to learn the physics needed to understand how a cellphone tower works.
    The words cheap did not motivate this person! But challenging does because he found the correct parts designed by the same companies.
    I am not discouraging you, but hope you understand a clear reason to try.
    Clem
  • clem57
    clem57 over 10 years ago in reply to clem57
    Use a Raspberry Pi in The PiPhone Is A DIY Cellphone Powered By Raspberry Pi | TechCrunch
  • clem57
