Legacy Personal Blogs How to detect external switch status
  • Date Created: 26 Feb 2013 7:00 PM Date Created
  • Views 867 views
e14 Contributor
e14 Contributor
26 Feb 2013
I have got a project to design a circuits to control and detect an external electrical circuit. The project should complete these functions as I list below.
1. I cut off external circuit and connect two broken wire terminal to a relay in my board to realize turn off/turn on external circuit. It is not a problem.
2.  Detect external circuit loop status (Open/Close)
3. Detect the relay status in my PCB(On/Off)
4. All my controll circuits should be isolated to external circuits.
5. The voltage of external circuit is 24VDC/24VAC
Please review attachement.  K1 is a relay of my project. Besides k1, I have to add a detection circuits to detect S1 status(if it is open/close).
All my circuits should be islolated to external circuit. The basic rule is cheap and reliable.
Best regards
Jim
    DAB over 13 years ago
    Hi Jim,
    I would go with optoisolators to do the detection.  They will only turn on when current is being pulled by your external device, plus they isolate your board from any spike issues with the external load.
    The same goes for your relay.  The same current that flows to activate the relay would power the isolator, giving you a signal only when the relay is in use.  The trigger logic is simple and you eliminate a lot of potential issues with current and load variances.
    Just a thought,
    Hi Jim,
    Just a thought,
