Legacy Personal Blogs How to detect external switch status
  • Date Created: 26 Feb 2013 7:00 PM Date Created
  • Views 868 views
e14 Contributor
e14 Contributor
26 Feb 2013
I have got a project to design a circuits to control and detect an external electrical circuit. The project should complete these functions as I list below.
1. I cut off external circuit and connect two broken wire terminal to a relay in my board to realize turn off/turn on external circuit. It is not a problem.
2.  Detect external circuit loop status (Open/Close)
3. Detect the relay status in my PCB(On/Off)
4. All my controll circuits should be isolated to external circuits.
5. The voltage of external circuit is 24VDC/24VAC
Please review attachement.  K1 is a relay of my project. Besides k1, I have to add a detection circuits to detect S1 status(if it is open/close).
All my circuits should be islolated to external circuit. The basic rule is cheap and reliable.
Best regards
Jim
    Hi DBA,
    Thank you very much for your response. In fact, besides isolation, cost is another very important factor that we have to consider. An important thing is that the current of the external circuit is not very big(500mA), so we couldn't use hall effect components and if we use an isolated current sensor, we have to add an amplifier and it is too complex for the detection circuit.
    I use the chip LDA110S (that has about 1ma forward current, it is a little big and would affect external circuit,I connected LDA110S cross relay contact with a seriel current limitation resistor). Besides LDA110S, I have to add another circuit to detect the external circuit status when the relay on board is closed.
    Best regards
    Jim
    Hi DBA,
    Best regards
    Jim
